It is currently Sun May 19, 2024 7:38 pm
PostPosted: Thu May 02, 2024 3:18 pm
Hi am new to the site and I have purchased my first pilot that I am trying to get back to life after it has sat for who knows how long outside. Thing were and are missing and so as I am putting it back together i just don't know how or where certain things go. Where do the 4 tubes coming out of the carb connect to? they all have little clamps on them but i cannot figure out where they all go to? Any guidance would sure be great.
(( EDITED by hoser added search words fir the future. Pilot carb FL400 carb Pilot carb ))
 Post subject: Re: Carb question
PostPosted: Thu May 02, 2024 3:45 pm
Welcome new guy.
This site is very dead now so you have to wait for answers.
There is an incredible amount of info on this site but you have to use the search box to find the stuff or wait for a reply.
Below is a link you can click on and in it is a lot of info and links to download a free manual.
viewtopic.php?f=2&t=18393&p=177700#p177700
Anything highlighted in blue you can click on and download something or just view.
PostPosted: Fri May 03, 2024 3:10 pm
The 1990 model had a small plastic overflow bottle to catch the gas during a roll over, then when you had the Pilot back on 4 wheels the gas it collected drained out on the ground. There is probably a picture some place here on the site, its shown in the 1990 service manual.
The two black tubes are vents the two clear tubes are vent tubes. Ensure they are clean on the inside, flush with carb cleaner and compressed air.
You have a service manual? Check out this link https://www.pilotodyssey.com/PO/viewtop ... 00#p177700
Look in the tank see if there is any rust or gunk in the bottom. Tank has a train on it, carefull removing might be rusted in, soak it good with PB Blaster for 24 hrs before removing.
Remove the fuel filter, fill it with gas, put your thumb and finger over the openings and shake it up good. Pour the gas out on white paper towels so we can see what comes out. You want to drain the filter from the INLET side. If the plastic on the filter is good and not cracking back flush it with carb cleaner until nothing comes out. It might sound hillbilly but I use to back flush once a season never had to change a filter. Honda made a QUALITY filter I never seen dirt in the float bowl.
Carb needs removed and the float bowl removed, same deal PB Blaster around the screws top and bottom, soak 24hrs before removing.
If you find a lot of varnish in the fuel system you need to flush all the fuel lines and blow them out with compressed air.
If there is a lot of dirt or rust in the gas tank flush it best you can and install a aftermarket filter in place of the stock filter for the first tank then switch back to the Honda filter. Every 3-4 gallons of gas through the tank remove the filter and back flush see if your finding anything.
More links
viewtopic.php?t=20987
https://duckduckgo.com/?q=PilotOdyssey. ... ave&ia=web
Good filter mod viewtopic.php?t=3211&highlight=prefilter
From the old days https://www.pilotodyssey.com/pilottech.htm
Main site https://www.pilotodyssey.com/
PostPosted: Sat May 04, 2024 4:58 pm
Thank you so much! I really appreciate it. I figured they were all drains but they have clips on them and clearly looked like they were attached to something so it threw me off. Thanks to the pictures that make sense now as there was a catch cup. Also thank for the cleaning process and steps. I will most def. do all that you suggest for sure. New to Pilots as i have wanted one for years and years but I am also new to two strokes. So again thank you for all your help.
Its been a fun project for my youngest son and I we've had alot of fun and are really hoping when its all back together that it will start and run. Hoping by then end of the month.
PostPosted: Tue May 14, 2024 10:50 am
Glad we can help there is an overwhelming amount of detailed information here at PilotOdyssey.com. Its been a community project with a common goal. Your new to this world so feel free to pick a topic and do a search to familiarize yourself. No question is a dumb question. Come up with your own ideas or thoughts create a post and share.
Number of posts: 172753
Number of topics: 16672
Number of users: 3981
Number of attachments: 63602
Board started: 16 Dec 2003 01:40 pm
Remember when your reading a post here in the forums at the very bottom of each page it includes a list of "Like Post" links to expand your quest, also use the search feature at the top of the main site. Google has indexed this site pretty well.
Do not forget here https://www.pilotodyssey.com/ and my older version if the site here https://www.pilotodyssey.com/indexBAK.htm
Go over the entire Pilot, change the Engine balancer oil and the transmission oil after a few tanks of gas, try to change after a ride so anything nasty in the oil is still in suspension and not in the bottom the cases.
If you do not know the age of the brake fluid and coolant probably a good thing to change them also.
Keep the front brake shoes properly adjusted and the Pilot will stop on a dime. Inspect the pad thickness on the rear disc brake do not run it down metal on metal and scar the disc.
Share any and all findings. Drain the oil in CLEAN pans, use separate pans so your not mixing the oil. CSI the drained oil, look at it in different lighting to see if there is any metallic in the oil. Its normal to see a light hue of metallic in the oil but if you see a LOT there could be a problem.
Every ride trip my modified Pilot received an trans oil change. When I was running my Pilot Engine the balancer oil was changed every other trip. I wanted my trans to last forever. Every year I changed my Engine coolant :-)
Registered users: adnoh, Bing [Bot], canadian oddy, CurtisR401, Google [Bot]
