Tire bead Joggles http://pilotodyssey.com/PO/viewtopic.php?f=1&t=1325 |
Page 1 of 1 |
Author: | mudbogger [ Thu May 12, 2005 9:48 pm ] |
Post subject: | Tire bead Joggles |
I am looking for a set of 6 ply tires with a joggle of at least .30-anybody got any imput on tires for this application, they are going on a set of OMF beadlock rims front and rear that I had purchased a year or 2 ago from A VENDOR off another board. |
Author: | moregoodlier [ Fri May 13, 2005 4:35 pm ] |
Post subject: | |
The joggle is the dimension on the rim between the clamping ring and the stationary ring.....what you are looking for is a tire that has a bead .30 wider than the joggle. So of the joggle measures .5 then you need a tire with a bead thickness of .8. I know there are hundreds of tires that will work, the only one so far that doesn't are mudlites (which blows because they are great tires)! Dan |
Author: | mudbogger [ Sat May 14, 2005 11:36 pm ] |
Post subject: | |
Thank you very much !!! |
