FL350 Fox 2.0 Rear shock install kit http://pilotodyssey.com/PO/viewtopic.php?f=1&t=17962 |
Page 1 of 3 |
Author: | CurtisR401 [ Tue Apr 03, 2018 3:08 pm ] |
Post subject: | FL350 Fox 2.0 Rear shock install kit |
Just wanted to let everyone know that I have been working with a local machine shop to reproduce the Works Performance shocks trailing arm bushings that are needed to install the Fox 2.0 shocks (Part# FOX-980-02-013). In addition to that I am also having them make a bushing to reduce the upper shock mount to accept the 1/2 bolt. I have received the test set and have given them the go ahead to make more. I should have them by the end of next week, maybe sooner. I currently have 15 sets being made and 2 of those sets are already spoken for. I wanted to offer them to the guys here before they get listed elsewhere. I do not have the cost yet because I have not paid them but it should be pretty reasonable. Also, I can include the hardware at an additional cost if you would like. NOTE: The Fox shocks are a 1/4 inch longer than the factory shocks & works shocks. Here are other threads that may be found useful: viewtopic.php?f=1&t=13024 viewtopic.php?f=1&t=17829 Cheers, Curtis Attachment: IMG_8087.JPG [ 58.62 KiB | Viewed 13871 times ] |
Author: | Randman [ Tue Apr 03, 2018 3:27 pm ] |
Post subject: | Re: FL350 Fox 2.0 Rear shock install kit |
Sign me up for a set! Rand |
Author: | Joker0370 [ Tue Apr 03, 2018 7:05 pm ] |
Perfect timing. Been looking for something like this, and I have $$$. I will take a set. |
Author: | CurtisR401 [ Tue Apr 03, 2018 7:12 pm ] |
You got it guys! I’ll keep you updated when I have the finished product and price. |
Author: | Squibward [ Tue Apr 03, 2018 7:14 pm ] |
Perfect timing for me too, rear shocks are shot! Sign me up :) |
Author: | go oddy [ Tue Apr 03, 2018 7:56 pm ] |
I would like to take a set off your hands as well. Thank you for the effort. |
Author: | Randman [ Tue Apr 03, 2018 8:55 pm ] |
Curtis, So we don't have to chase down hardware, you may want to offer that also with the kit. I don't have my Ody anymore to measure screw length. Also an added tidbit..... if memory serves me right, one of the spacers from the Fox shock kit has to be used to give the upper part of the shock sufficient clearance. Thanks, Rand |
Author: | scpilot66 [ Wed Apr 04, 2018 4:38 am ] |
I would like a set please. |
Author: | CurtisR401 [ Wed Apr 04, 2018 7:48 am ] |
Randman wrote: Curtis, So we don't have to chase down hardware, you may want to offer that also with the kit. I don't have my Ody anymore to measure screw length. Also an added tidbit..... if memory serves me right, one of the spacers from the Fox shock kit has to be used to give the upper part of the shock sufficient clearance. Thanks, Rand Rand, You will have an option to buy the kit with or without hardware. I do assume that most will want the hardware included. I will do a write up (w/pictures) of the installation of this kit with the hardware I have sourced. -Curtis |
Author: | Randman [ Wed Apr 04, 2018 12:31 pm ] |
Good Work! Rand |
Author: | CurtisR401 [ Wed Apr 04, 2018 1:10 pm ] |
FYI I recently purchased my Fox 2.0 shocks from http://www.polyperformance.com and they are currently running a 10% discount on them. Cheapest price I could find anywhere. That is a $48 savings = $432 shipped to your door. Promo Code: polyfb10 Cheers, Curtis |
Author: | RoboRex2005 [ Thu Apr 05, 2018 12:35 pm ] |
Awesomeness. I'm interested in doing the fox shocks so I'm glad you worked out the custom hardware. I may buy the shocks even sooner. Definitely cheaper route than the Farr rear suspension, but I still want bad. |
Author: | RoboRex2005 [ Sat Apr 07, 2018 3:51 pm ] |
Btw, what is the correct tool to fill these shocks and what pressure would you suggest? I've been researching but no good answer. |
Author: | CurtisR401 [ Thu Apr 12, 2018 9:27 pm ] |
So I picked up the bushings today. They were a little bit more expensive than I had thought but they did a great job on them and said they used high grade aluminum. Pricing includes shipping to the lower 48 USA. I will ship anywhere but will have to get a separate shipping quote for you. Full Kit = Aluminum bushings and Grade 8 hardware: $50 Bushings Kit = Aluminum bushings: $38 PM me if you are interested in ordering a kit. NOTE: Shocks are NOT included Attachment: UPPER HARDWARE.jpg [ 67.31 KiB | Viewed 13677 times ] Attachment: BOTTOM HARDWARE.JPG [ 59.78 KiB | Viewed 13591 times ] |
Author: | CurtisR401 [ Thu Apr 12, 2018 9:34 pm ] |
Here are some pictures of the install steps. Note: Install on rear left hand side (drivers side) Step 1: Remove existing shocks and hardware. Step 2: Grind inner frame upper shock mount flat. You want the washer to sit flush with surface & in parallel with the flat surface on the other side of the mounting hole. Attachment: GRIND FRAME.jpg [ 39.46 KiB | Viewed 13679 times ] Step 3: Install upper aluminum bushing. Be sure hole is clear of rust and debris. If you have to tap it in, use a rubber mallet. Attachment: TOP BUSHING INSTALL.JPG [ 46.97 KiB | Viewed 13679 times ] Step 4: Install trailing arm aluminum bushings. Same as upper but on either end of trailing arm mounting hole. Step 5: Upper shock install. Attachment: UPPER SHOCK INSTALL.jpg [ 42.36 KiB | Viewed 13679 times ] Step 6: Lower shock install. Attachment: TRAILING ARM INSTALL SETUP.jpg [ 65.74 KiB | Viewed 13679 times ] Step 7: Adjust rear link evenly and as needed to fix camber. Attachment: REAR LINK ADJUST.jpg [ 46.46 KiB | Viewed 13679 times ] Step 8: Adjust shock pressure as needed. 250psi is a good starting point. (160lb person) Finished product Attachment: IMG_8193.JPG [ 90.67 KiB | Viewed 13678 times ] |
Author: | CurtisR401 [ Thu Apr 12, 2018 9:40 pm ] |
Additional photos. Axle bind clearance. Attachment: IMG_8191.JPG [ 33.95 KiB | Viewed 13677 times ] Attachment: IMG_8190.JPG [ 19.04 KiB | Viewed 13677 times ] Fox 2.0 VS Works Performance *** it is not on the jack stand *** Attachment: Rear Comparison.JPG [ 61.29 KiB | Viewed 13677 times ] |
Author: | Randman [ Fri Apr 13, 2018 1:23 am ] |
Excellent pictorial and write up! PM Sent! Rand |
Author: | MikeW1573 [ Fri Apr 13, 2018 11:27 am ] |
Excellent write up and I appreciate the time and research you put in to having these developed/made for this community. I should be able to provide some feedback after this weekend on the how the Fox Shocks compare to the stockers and how the bushings hold up. How much did you have to adjust to get the chamber correct on your machine? Thanks again! Mike |
Author: | CurtisR401 [ Fri Apr 13, 2018 9:14 pm ] |
Thanks guys! It is humbling to know that my efforts are appreciated and I am glad that I can help. These shocks are a great option for any FL350 owner and with an easy install kit they are now much more appealing. Mike, I adjusted the rear link about a 1/4 inch in total to make up the difference. I am looking forward to your review! -Curtis |
Author: | ValleyFR [ Fri Apr 27, 2018 10:43 pm ] | ||
Post subject: | Re: FL350 Fox 2.0 Rear shock install kit | ||
I've received the goods, should have them installed soon with an update once we get the cattle to grass!
Author: | Squibward [ Tue May 01, 2018 8:12 am ] |
Iv tried 4wheelparts/offroadwarehouse/ployperformance and everyone is on backorder and had to cancel my purchase haha great! Anybody know of a place that has these shocks in stock? Lol |
Author: | CurtisR401 [ Wed May 02, 2018 7:53 am ] |
Squibward wrote: Iv tried 4wheelparts/offroadwarehouse/ployperformance and everyone is on backorder and had to cancel my purchase haha great! Anybody know of a place that has these shocks in stock? Lol This site should have them in stock. Call first but another person just ordered from here. Apparently these shocks are now in high demand... I wonder why? https://www.kartek.com/parts/fox-racing ... rvoir.html |
Author: | CurtisR401 [ Thu Jan 03, 2019 11:27 am ] |
I wanted to bump this thread... I can't believe that no one on here has given this kit a review?!?! A lot of you purchased them... Yet, a stranger on ebay did. https://www.ebay.com/itm/Honda-FL350-Fo ... :rk:2:pf:0 I will still honor the price listed here, if purchased through this site. -Curtis |
Author: | go oddy [ Thu Jan 03, 2019 1:13 pm ] |
CurtisR401 wrote: I wanted to bump this thread... I can't believe that no one on here has given this kit a review?!?! A lot of you purchased them... Yet, a stranger on ebay did. https://www.ebay.com/itm/Honda-FL350-Fo ... :rk:2:pf:0 I will still honor the price listed here, if purchased through this site. -Curtis I have not yet installed. How is this for a review? I’m in no rush to install because... with the depth of your character I know they’ll be perfection. With a little one, I just haven’t had the time. |
Author: | CurtisR401 [ Thu Jan 03, 2019 4:42 pm ] |
I'll take what I can get at this point LOL I realize that some may not have installed the shocks yet. I know that some have with no feedback. I guess no news is good news... |
Page 1 of 3 | All times are UTC - 5 hours [ DST ] |
