It is currently Sun Nov 10, 2024 3:43 pm
 Post subject: Leckich top end rebuild
PostPosted: Fri Jul 05, 2019 5:10 pm
Putting 82 mm piston in leckich was 81.50. Cylinder bored and honed. Got piston back lightened and hole pleced per build instructions. See pics. Anyone know weight of factory piston? Chamfer ports then install.
PostPosted: Fri Jul 05, 2019 7:05 pm
Here is some info I got on my computer. It was all taken from various threads on our site here.
There are some links as well.
Piston weights:
Here are some piston weights, all FL350R
Honda/Art 80mm: 11.8 oz
chucklenuts at aftershot motorspurts/Wossner 82.5mm: 11.7 oz
Wiseco 80mm with chucklenuts at aftershot motorspurts mods 12.8 oz
Wiseco 81.5mm: 14.2 oz
Wiseco 82mm: 14.68 oz
Not only is lighter better for power by reducing reciprocating mass, keeping the weight close to the original reduces vibration. The counter balancer was designed to match up to the original piston weight.
Rocket: Just a little FYI, I've been reading that the new pistons weigh more, and while I was in the market for a new one, I did a little checking. I called Wiseco and talked to there tech dept.
and I was told that they changed design in 2007 and no longer made the lightweight piston.
So I just ordered a new one and planned on just machining it down to match my old lightweight one.
Old design piston weighed 343.8 grams
New design piston weighs 413.6 grams
After all the machining to the piston I was only able to get it down to 367.7 grams.
The wrist pins are also more new 50.5 grams, old 48.5 grams
Hoser: IMO they have always been a sorry excuse for a piston they are "forged" alright complete forgery not many know it but the same master company that owns wiseco also owns about every piston mfg on the planet that makes non OEM pistons and even some OEM pistons once they had their monopoly running is when they cut the machining then raised the prices on pistons about 40% now that everything is global who you going to call, I was asking this when bush made the phrase "global economy" popular, think the company behind the monopoly was "Dover Industries" ???? Might have changed hands by now but at one time they owned Carillo Rods, ProX, JE, Vertex , ART.
Think the prices has increased by 50% since fall of 2008
On my list of things to do I want to make a jig for the drill press so I can drill the holes in the wiseco pistons above the pin like wiseco use to do it would just be a round hole as big as I dare to go to match the diameter of the hole wiseco machined it won’t be the same oblong hole wiseco machined or be as light but will be lighter than delivered also will look at drilling a hole or dimple below the pin and along side the pin.
Info is taken from this thread: viewtopic.php?f=1&t=10677
Speedchaser: Hello got a new wiseco fl350 80.5 mm piston kit and they changed from the old style
and are heaver how much will this affect on performance being heaver and with more surface area
stock 78.5 mm Honda art piston with pin installed 374 grams
stock 78.75 Honda art piston with pin installed 380 grams
wiseco piston 80 mm with pin installed old style 357 grams
wiseco piston 81 mm with pin installed old style 355 grams
wiseco piston 82 mm with pin installed old style 407 grams
wiseco piston 80.5 mm with pin installed NEW style 407 grams
Info taken from this thread: viewtopic.php?f=1&t=7444
PostPosted: Fri Jul 05, 2019 7:20 pm
That's what I needed after all machining and lightning to new wiesco 82 mm was able to get to 11.20 oz. Should be close. If wrist pin lil heavier then maybe even closer.
PostPosted: Sat Jul 06, 2019 9:33 pm
Another picture to show where he lightened and took weight off.
PostPosted: Sun Jul 28, 2019 10:57 am
Got 82 mm bore leckich back in buggy. Waiting on exhaust ring for manifold should be here Thursday. Will post compression results. Big bore gonna be winter project.
PostPosted: Wed Jul 31, 2019 11:13 pm
Got it all back together. Ran compression check 215-218 lbs . Looks like race gas for this puppy. I love the way it smells with motul 8 anyways! Lol
PostPosted: Fri Aug 02, 2019 9:50 pm
dam that's some compression, c12 for you my friend. I use motul 710 and avgas. I had 200 but had my head bowled out more to lower compression..should run strong
PostPosted: Sat Aug 03, 2019 6:07 am
Yeah bit to strong! After starting for heat cycles lil too much compression. Sounded like some detonation even with the race fuel. Had a copper cylinder spacer put it on checked port timing looks good. Checked compression it's 185 now should be great.
Registered users: Bing [Bot], eseymour72, Google [Bot], hoser, Lanix, MSN [Bot], MSNbot Media, W3C [Validator]
