It is currently Fri May 10, 2024 5:39 am
 Post subject: Piston weights
PostPosted: Wed Jul 10, 2019 9:20 am
I know wiseco is only piston choice. New ones are alot heavier than stock were. Just wanted to know how badly this is on vibation being heavier than factory piston. I think anyone using these should have piston machined to factory piston weight if they can. Could Engine longevity be an issue with these pistons?
 Post subject: Re: Piston weights
PostPosted: Wed Jul 10, 2019 12:12 pm
I don't know the answers to your questions there so I hope someone like methodical or speedchaser will chime in.
I bet the internals, Engine casings etc will be able to handle the extra vibration but I bet my rent money that Engine mounts will take a beating. I just replaced two Engine mounts on my brothers machine last week. This is the ported and piped Engine. It had a real bad vibration. I changed the counter balancer bearings because I saw flaking in the oil but when I took it apart the bearings looked ok. Then I saw the rear two Engine mounts ------ they were toast.
My money says the heavier wiseco's will take out mounts.
PostPosted: Wed Jul 10, 2019 1:36 pm
Also the new wisecos don't have the relief cut on sides like factory. Not as much airspace in crankcase piston area. Just something else to ponder. I know when raced dirt bikes did always port match cases to cylinder sometimes had to add material sometimes remove some.
