It is currently Wed May 22, 2024 6:29 am
 Post subject: Spark issue question
PostPosted: Sat Dec 14, 2019 6:18 pm
I have a gen 2 fl250 just finished restoring it and it ran fairly good. It seemed the idle was a bit rough. I used it for about a week and then It wouldn't spark. I thought I had a bad coil and bought a new one. It ran after that for about 1 hour then the same issue. I am not too familiar with these. I am getting fuel and the stator checks out with the multi meter. I am getting some resistance between stator ground and the motor (( Internal Combustion Engine ? )) case, this seems wrong. This has a CDI (Capacitor Discharge Ignition) which I think is good, but I don't know how to test it. The ignition swith checks out and I tried just unplugging the wires to make sure. This has a starter on it but I don't have it tied into a charging unit yet. Any Ideas? I did some searches and didnt find any clear answers. Thanks
 Post subject: Re: Spark issue question
PostPosted: Sat Dec 14, 2019 6:46 pm
Welcome new guy.
This site is very very slow now. You have to wait for answers sometimes.
Here is a very good thread you may want to read: viewtopic.php?f=1&t=18349
Also at the very bottom of any thread you read will be an area where there a similar threads to the one you are reading. You can click on them to read.
I am a millwright and NOT an electron mechanic so I can't really help you on this.
PostPosted: Sat Dec 14, 2019 11:29 pm
Have you tried unscrewing the spark plug boot and trimming a little off the wire and reconnecting to make sure you have a good connection with the spark plug wire and boot? Just thinking out loud ... good luck and welcome to the site
