It is currently Fri May 10, 2024 4:27 pm
 Post subject: Powerbloc puck weight
PostPosted: Tue Oct 20, 2020 1:31 am
Does anyone have a powerbloc clutch on their FL350 ??
The unit I'm building has the black spring.
I want to know how much one puck/w-weights weighs on a calibrated unit.
Thx for any replies.
PostPosted: Tue Oct 20, 2020 1:38 am
If the weights are the same as ones which come on the PB FL400 clutch, each weight is 3.60g as just measured on my micro-scale which I use for tuning clutches.
PostPosted: Tue Oct 20, 2020 1:46 am
Wow thanks for quick reply.
What I want to know is the total weight of the puck with weights.
PostPosted: Tue Oct 20, 2020 2:30 am
Well researching this site in "Powerbloc central" -- I come up with anywhere from 4 weights to 12 weights. Hoser was running 4 weights on the Pilot apparently, way back in the day. So I figure if I split the difference and run 6 weights that should be close enough.
So if each weight is 3.6 grams then that's 21.6 grams.
Thanks for the info.
PostPosted: Tue Oct 20, 2020 3:35 pm
Took the Powerbloc pucks apart and weighed everything. Pic below.
Please note: I have NO idea if this clutch was ever calibrated for the oddy it was on. It came with an oddy I bought years ago and the offset was wrong so it ate belts. I just threw it in the corner until now.
Based on my research here on this site, I think I have to run more weights. The 7 weights are not enough apparently. Maybe I will just weigh some washers in my bins and add them, but for now that is the least of my worries. Still have to do a bunch of machining.
Also note that this clutch does not have a "D" on the shaft or cover. It's just a round. Not sure if this is good or not but that's what I got here. This thing must be real old.
