Hello everyone,
I am wondering if I could get some advice on the following:
Rear BrakeI have the original brake calliper from this machine. However, It is missing the grommet for the shoe on the one side.
I am wondering if anyone would have any recommendations to switch over to a hydraulic and/or another mechanical brake calliper (aftermarket and/or another power sport vehicle that someone has done a conversion from)?
I am also not sure if this is the original brake rotor. The rough dimensions I got from the one on it were the following:
8.17 mm thick / 0.3215"
OD 39.07 mm / 1.538"
Rotor across 212.13 mm /8.352"
Steering Wheel ControlsI am wondering if anyone has also modified their steering wheel with a light switch, ignition button, etc. I would appreciate some feedback. I have the original plastic cover plate that hides the cables and mechanism as shown in the attached picture, but it is deteriorating substantially!
ClutchAs you can see in the attached pictures, someone along this Odyssey's journey in life has replaced the original 250 2-stroke w/ a belt torque converter to a 4-stroke 420cc Princess Auto Power fist with chain drive (hence the lack of braking system at the moment).
The
motor ((
Internal Combustion Engine ? )) runs, however it engages at idle i.e. the machine wants to "take-off"! I have a basic understanding on clutches but I would appreciate all feedback and recommendations on either replacing the clutch, plates, what to look for and troubleshooting!
Engine mount supportI am wondering if this should be flush mount should be flush with the original frame?
I realize that this is not an all stock machine but I have always wanted an Odyssey and it is a perfect addition to my ATC!
Thanks everyone!
I look forward to your comments.
