go oddy wrote:
I’ve used these guys… they were great, even made a custom back cut into the spacers for me.. hope this helps.
http://tireshopsupplies.com/So, just got off the phone with this website you suggested above and they can make a dual bolt pattern spacer, with no studs, just through holes.
OrderedSpecs for Custom Spacer4/110 and 4/130 bolt pattern88.9mm (3.5") center bore diameter158.75mm (6.25") Outer Diameter3/4" Spacer Thickness10mm Through Holes for (10mm x 1.25 Studs)1 Custom Spacer=$40 plus s+hThanks again for the response and helpful info, it's now gonna get the job done.
Matt
*Update on ordered spacer*Received my order in the mail today, and upon inspection the holes looked way too big. So checked with digital caliper and 4/110mm bolt pattern holes are 12.78mm, and 4/130mm bolt pattern holes are 14.78mm. Way too big to be used as a template for drilling proper bolt pattern holes, which is what I told them when ordering on the phone. Also wanted 10mm through holes only for both bolt patterns, they made the lug nut recesses in the 4/110mm bolt pattern. Could have still done the job if not for the oversized holes throughout. Gonna have to call to them today if they are open, we'll see what they say.
Here are the pics:Attachment:
