It is currently Tue May 07, 2024 9:53 pm
PostPosted: Fri Oct 06, 2023 12:57 am
How much HP does a pipe add ?
According to some dyno results I've found online, which were run on a stock Banshee, a pipe adds between 1 and 5 HP and adds 1000 rpm to 1500 rpm.
These results were taken from 10 different manufactures of pipes (NOT the manufactures testing).
Makers were: DG, DMC, DYNO PORT, FMF, GRAYDON, LRD, PRO CURCUIT, PSI, TURNER.
Worst was: Dyno Port and DG with a 1 HP gain and 1.1 HP gain.
Best were: Graydon, LRD, and Pro Curcuit with 4.5 HP to 5 HP gain.
Lots of bad mouthing about DG being slightly better than stock but were the cheapest pipe out there. The dyno results seemed to prove it.
The bad mouthing continued with respect to pricing (I don't know current prices). Apparently the DG is not worth the money anymore because for a hundred or two more you could get real gains on a Banshee.
But based on those numbers it tells me what I have said here in past posts. NOBODY is going to notice any difference in performance because the azz dyno is not that accurate.
The Banshee has 41 HP. That's close to the Oddy 34.2 HP I got on my dyno results when the clutch exploded.
The Banshee is a two stroke 350cc twin cylinder Engine.
PostPosted: Fri Oct 13, 2023 8:13 pm
All I know is my DG on my last fl350 about blew my ear drums out.
PostPosted: Thu Oct 26, 2023 5:19 pm
LOL yep
PostPosted: Sun Nov 05, 2023 5:28 pm
If your looking for a Banshee pipe hit the Banshee forums, you will have to decide what you want torque or rev pipes.
PostPosted: Wed Dec 13, 2023 10:34 pm
I had a '88 banshee, added a set of Toomey pipes with their dynojet kit, that woke it right up, not sure how much but noticably, then had some porting done on it and that turned it into a beast!
Registered users: Baidu [Spider], bennett24, Bing [Bot], galimberti, Google [Bot], Lanix, Rppjr
