PilotOdyssey.com
http://pilotodyssey.com/PO/
Broken fuel return?
http://pilotodyssey.com/PO/viewtopic.php?f=1&t=20990
Page 1 of 1
Author:  skuse [ Fri Oct 13, 2023 1:16 pm ]
Post subject:  Broken fuel return?
Hey all... long time lurker, first time poster. Just picked up an '89 pilot! Always wanted one since they first came out (yes, Im that old) and finally found one. Everything is super solid.. only challenge is the fuel return seems broken. Not sure exactly how to fix it. Doesnt look like anything is cracked/broken... just wont stay seated. Thoughts? Just use some RTV?
Author:  liduno [ Fri Oct 13, 2023 8:08 pm ]
Post subject:  Re: Broken fuel return?
I’ve only ever owned odyssey’s, so take it for what it’s worth, but does it twist into place?
Author:  rmesser [ Sat Oct 14, 2023 9:50 pm ]
Never seen one come apart before. I believe that is a one way valve, to stop fuel from back flowing if tipped over. RTV might not be the best choice. I would look for a clear bonding glue, maybe even an epoxy. Make sure it is rated for fuel contact. I would also remove it from the hose and gas tank and clean it very well with some degreaser before gluing. Be careful with the gasket so you can reuse it.
Why2 hose clamps? Or is that just the clamp from the 3 way valve?
Might be a good time to drain the fuel tank and inspect. Clean the top of the fuel tank before you begin. Don’t want that dirt in your tank.
Take your time when working on your machine. They are old school 2 cycle and many parts are hard to get. Don’t be a caveman. Get a bigger hammer does not apply to these machines. Make sure you have and read the service manual.
Author:  skuse [ Wed Nov 15, 2023 11:58 am ]
Finally got back to it... looks like there never was any type of locking tab or anything... Originally either glued or just pressed in. Either way, a touch of JB weld and will be back in business.
Author:  issacrix [ Tue Feb 13, 2024 6:41 pm ]
Post subject:  terrific content!
This is just a great site to learn new things!
Author:  hoser [ Wed Feb 14, 2024 8:20 am ]
Pretty sure that is suppose to be a check valve/vent so when your upside down fuel does not run out of the tank. Looking at the DIRT inside the valve the gas tank will need a good cleaning and the fuel filter will need replaced. Remove the float bowl from the bottom of the carb and see what is in the bottom. Post as found pics.
I would remove the gas filter and back flush it, put your finger over the inlet side, spray carb cleaner in the outlet side, cover with your thumb and shake it up good, remove your finger from the inlet side and let it pour out on a paper towel to see what comes out.
I have cleaned/flushed used fuel filters and reused many times on all applications with no ill affects, especially the OEM filters, just make sure when you think you have it cleaned by shaking run a quart of gas through the outlet to back flush it really good then a few cups of gas through the inlet side to see what is coming out the filter ensuring its clean. Do not blow out with compressed air!!! Put a hose on it and blowing through by mouth is ok and should not damage anything.
Check to see if that check valve is still available from Honda. That round disc might have been the check valve diaphragm and not a gasket?
The gas tank has a drain plug shake up the Pilot to stir up the gas and drain into a pan show us how much dirt came out.
Author:  rmesser [ Wed Feb 14, 2024 10:05 am ]
Post subject:  Re: terrific content!
Yes it is. Much better than FB !
Author:  hoser [ Wed Feb 14, 2024 9:14 pm ]
Facebook users should encourage others posting on Facebook to post here then link there post on Facebook so Pilot Odyssey owners has a organized, centralized database of data.
https://www.phpbb.com/
