rppjr busted parts repair http://pilotodyssey.com/PO/viewtopic.php?f=1&t=21003 |
Page 1 of 1 |
Author: | canadian oddy [ Sun Dec 31, 2023 4:30 am ] |
Post subject: | rppjr busted parts repair |
Attempting to repair some broken parts. https://youtu.be/Rj4QP2x1LNA CO |
Author: | canadian oddy [ Mon Jan 01, 2024 3:15 am ] |
Post subject: | Re: rppjr busted parts repair |
https://youtu.be/2qQEsHXOblA Part 2 CO |
Author: | canadian oddy [ Fri Jan 05, 2024 4:07 am ] |
Progress report. https://youtu.be/WQio2T944bQ CO |
Author: | canadian oddy [ Sat Jan 06, 2024 12:05 am ] |
Part 4 https://youtu.be/UzDzMM4njDo CO |
Author: | canadian oddy [ Sun Jan 07, 2024 4:06 am ] |
Part 5 - Final https://youtu.be/SuGO0dwU_hY CO |
Author: | hoser [ Thu Feb 15, 2024 1:45 pm ] |
canadian oddy wrote: https://youtu.be/2qQEsHXOblA Part 2 CO What model Tig welder is that, the glimpse I caught it looks like mine, Repair looked good so far, what caused the damages? I assume that upper hole in the case is the input shaft bearing area, any way to modify that area to accept a double row bearing? IMO ALL these CVT transmissions I have seen should have had double the thickness on the cases for the input shaft and double row bearings both sides. I am including all ATV's, UTV's, tractors of all types, snowmobiles etc. |
Author: | canadian oddy [ Thu Feb 15, 2024 1:55 pm ] |
hoser wrote: canadian oddy wrote: https://youtu.be/2qQEsHXOblA Part 2 CO What model Tig welder is that, the glimpse I caught it looks like mine, Repair looked good so far, what caused the damages? I assume that upper hole in the case is the input shaft bearing area, any way to modify that area to accept a double row bearing? IMO ALL these CVT transmissions I have seen should have had double the thickness on the cases for the input shaft and double row bearings both sides. I am including all ATV's, UTV's, tractors of all types, snowmobiles etc. It's not a tig welder but I wish I owned one. Can't justify the expense. It's a Millermatic 180 auto set with a 150 spool gun. I also own a mig wire machine (next to it) and a 140 amp AC/DC stick machine. I would really like a AC/DC tig machine so come on lotto !! CO |
Author: | hoser [ Thu Feb 15, 2024 2:01 pm ] |
canadian oddy wrote: Did you use a adjustable fly cutter on the inside of the input shaft bore? |
Author: | canadian oddy [ Thu Feb 15, 2024 2:46 pm ] |
hoser wrote: canadian oddy wrote: Did you use a adjustable fly cutter on the inside of the input shaft bore? No -- I cut a piece of round stock in the lathe with the correct sizes (allowing a couple of thou for some shrinkage) and then built up the aluminum weld around that metal piece I machined. CO Edit: Yes I did actually use a fly cutter to clean up the inside of that welded area. The plug I made was not perfect so the size was a bit off. CO |
