Have not been able to work on it too much as it has been so hot here 104 plus every day so my shop has been over 120 not even good to work in at night. I very much appreciate all your help i really need it. Okay so that makes sense why fluid did not get pulled back into the radiator if it only pulls it back when its cools. There does not seem to be any specks in the coolant or the res tank. The radiator is super clean as we just had the entire buggy apart and it was completely cleaned up inside and out. The
Engine was rebuilt not long before i bought it and installed it. It still will not start and the pull start does not seem to have the resistance it had before. Prior to this it was very hard to pull, very hard actually could not imagine having to start it that way. Now it seems to be much easier to pull.
It is starting to cool off now and my son and I are starting to get over the huge let down of this and want to get back out and get her running again. It was just really discouraging as it was running so well and we just finished rebuilding her. So it was a major bummer and it just felt like it was avoidable.
So where should i look first what could it have done to the
motor ((
Internal Combustion Engine ? )) to make it no longer run or start? I worry even though it was shut off quickly that it did some major damage.
Also the upper cage is not chrome. We sand blasted it to get off all the rust and my son wanted to paint it silver. I for sure checked all the welds during that process.
Thank you again for all your help it is appreciated more than you know as i am new to 2Stroke motors.
