Well I just logged in and seen this.
Hoser is correct ---- I was not trying to be a clown.
I'm an industrial millwright (retired) and in my trade we are not a politically correct group. I guess I just come across "wrong" to some people. It's just how I am and how almost all of my co-workers are, even at all of the different work sites and companies I've been at.
Hoser is also correct in pointing out at the fuel issue stuff.
I've spent a lot of money knowing what I know about these machines and I've learned the most off this site.
I've melt almost a dozen pistons before I figured it out and the sick part is, that when I went back and read one of the replies in my very first post on the issue, a commenter actually pointed it out but I missed it. Stupid me.
Now I'm going to take a shot at you about your post.
canadian oddy wrote:
Where do you get that 4.5 ounces in 10 seconds flow rate? that's not in the factory service manual.
It's not in the manual. They left it out but if you have a Pilot (FL400) manual it's in there.
You're telling me 40 year old plastic is brittle? That's funny.
You can laugh if you want but most of these machines have been kept outside. One of the tell tale signs a machine has been out in the sun a long time is by looking at the kill switch. Many are orange in color. They are suppose to be red.
This also means things like the fenders have been in the sun and they will shatter as soon as you lightly hit something. If you look close you'll see all of the "stars" in the plastic. It has fractures everywhere.
The check valve is still available new 16710-VMO-770
Thanks for that info. I tried to get one of those when I busted mine many years ago and my local Honda dealer said they couldn't get it.
Onebigasstruck wrote:
I've read a lot on here and in the past 24 hours created a whole fuel system. I got 6 oz per 10 seconds right out of the fuel bowl cap.
It's an electric pump with a tee in the supply line and a Holley carb jet in the tee.
oohhhhhhhhhh
Yes I know the threads you have read now.
6oz in 10sec is lots but that also tells me you got a big electric fuel pump.
It's mostly likely not a Quantum but some automotive pump and you are trying to regulate the flow/pressure by bleeding it off with a jet.
That's difficult to get correct.
Also of note is that the Oddy electrical system is pathetically small. Electric fuel pumps use up a lot of juice. The Quantum is very low draw unlike an automotive pump. You may kill your battery.
I also now know why your question about an electric pump when I made my original comment.
You are heading down a wrong road.
Good Luck. Keep us posted.
