Turbotexas wrote:
I am leary about plugging the hole on the other side or magneto side... IF your vent gets plugged up wont this create back pressure that will blow out a seal??? Randy shows his method is to plug the hole on the balancer gear side, so if there is blockage it wont cause an air leak in the seal behind the balancer gears...
If the case vent gets plugged it can build pressure and blow the seal.
Does not matter where the crank case vent is located if its plugged it builds pressure in the same location.
The affected seals from the over pressurization would be the same, the crank seal on the clutch side this would suck balancer oil into the crank case of the
Engine OR it would leak oil out behind the clutch, on the 350 the seal you see behind the clutch is the balancer case seal, balancer oil is behind it, on the Pilot the seal you see behind the clutch is the crank case.
So where I plug the old vent system does not really matter if the new vent becomes plugged the end result is the same, where and how I plug the old vents system is real easy and the screw I used is real handy you also can undo my plug and restore the factory vent system real easily if you ever felt the need to.
Just trying to find the fast east effective way to install the new vent or quick and dirty as I like to call it lol, the way I installed a new vent on Mudbogger's Engine was more complicated than I like.
viewtopic.php?f=26&t=3596&start=75
