It is currently Sat May 11, 2024 10:29 am
PostPosted: Sun Dec 28, 2003 3:50 am
Is it possible to access any of the old site, particularly the "super search" option for technical advice/info.
Just in case the answer is "no" my questions are...
On the microfiche for the Pilot, under "Rear Wheel" I am wondering about #15 , the Ring set. It says the size is 26 x 2.0 I think I remember from the old site someone saying that Honda made two sizes and that the smaller one is preferred for ease of removing the axles and/or maintenance - Is that true??? And if there is a smaller size what exactly is it and how do I get a pair? Also, just by comparison of my old ring sets to the new ones (above size) I can tell that the old ones were smaller (about a 26 x 1.8). Please help!!! Thanks in advance.
P.S. Will 25 x 13.5 - 10 ITP Spider Tracs fit onto an ITP 10 x 8 rim that will work on the Pilot without interfering with the rear knuckles, suspension, and/or travel??
PostPosted: Sun Dec 28, 2003 5:22 am
Yes it is back up
I think you need to order both to ensure you get the right ones, they changed sizes somewhere in their production run
I have set of those on 8" aluminum if you want them....One rim has a good bend in the bead but still holds air fine...we find them too wide....great traction....fit fine...just not our cup of tea, email me if interested
PostPosted: Sun Dec 28, 2003 9:49 am
Order both sizes they are less than a buck each they you know you will have the right size when you assemble.
PostPosted: Sun Dec 28, 2003 1:09 pm
Thanks guys, help much appreciated! As for the rims and tires, ludedude, i'll hold off for now but thanks for the offer.
PostPosted: Mon Dec 29, 2003 3:11 am
P.S. Will 25 x 13.5 - 10 ITP Spider Tracs fit onto an ITP 10 x 8 rim that will work on the Pilot without interfering with the rear knuckles, suspension, and/or travel??[/quote]
The pic below is a 25x13.5-10 Spider Trac. The knuckle is normally round, right?
File comment: This tire has 7 lb in it. Hope this helps.
PostPosted: Mon Dec 29, 2003 3:50 am
The pic below is a 25x13.5-10 Spider Trac. The knuckle is normally round, right?[/quote]
What rim offest is that on though...I'm sure the ones Ted had on did not hit.
PostPosted: Mon Dec 29, 2003 3:33 pm
What rim offest is that on though...I'm sure the ones Ted had on did not hit.[/quote]
They are ITP steel wheels, not positive the offset. They don't really "hit" so much as rub - they ARE 13.5 " wide.
PostPosted: Tue Dec 30, 2003 2:04 am
Yes, the knuckle is usually round.
As for the offset of my rims they are 3 +5, which I believe to be the same as the stock Pilot rims.
As far as the picture goes(which I thank you for providing) I think that says enough - I'm gonna move down a size, probably 12 inches wide.
PostPosted: Tue Dec 30, 2003 8:52 am
stock is 4+5, the 13.5 work fine with the 3+5, 1" less towards the machine.
PostPosted: Thu Jan 01, 2004 10:31 pm
Thanks LudeDude.
