Drakart clutch cover. http://pilotodyssey.com/PO/viewtopic.php?f=110&t=2273 |
Page 1 of 1 |
Author: | litespeed [ Sun Jun 25, 2006 11:37 am ] | |||
Post subject: | Drakart clutch cover. | |||
The pictures are worth a thousand words but just in case, My clutch kept filling up with sand and actually "sand blasted" most of the numbers off of my Ski-Doo clutch from there not being a cover of any kind so I decided to make something. I bought a 1/2 sheet of 1/8" aluminum and got to some thinking. It allows to change the belt and the adjustable ramps on the TRA clutch but seems to keep 90% of the sand off the clutch. Untill one day I get off my ass and build a completely sealed belt drive similar to what the quads have, this one will do fine. Any Drakart owners that want details just let me know. Tom
Author: | hoser [ Sun Jun 25, 2006 11:55 am ] | ||
Post subject: | |||
How about a filler piece on the bottom my mid skid on my Pilot keeps all kinds of sand off the clutch . http://pilotodyssey.com/PO/viewtopic.php?t=529
Author: | DunePilot [ Sun Jun 25, 2006 10:35 pm ] |
Post subject: | |
Hey Litespeed, don't forget to close off the side panel opening. It is a direct path to the front/open end of the drive clutch. I closed off mine, noticed a huge difference in the belt life. Not so sure about fully enclosing the clutches and drive belt like the Polaris. Alain used to have a similar setup, but the belts didn't last due to too much heat. All you need is a shield which covers the front, open end, then slightly over the top of the clutch and slightly over the side. Hope that's clear as I don't have a pic to show you what I mean.... DP |
Author: | Drakman [ Sun Jun 25, 2006 11:49 pm ] | |||
Post subject: | ||||
I was going to do something like this to the twins. I found a couple of large cooking pots, I had one set up to go on, but it got bent on the way to Killpecker, so it never got used.
Author: | litespeed [ Mon Jun 26, 2006 12:54 am ] |
Post subject: | |
I didn't want to take too much of the airflow away from the clutch completely so that is why I left the front vent open. Sand is very minimal at the clutch now but it is there none the less. My idea for a belt cover/enclosure will be force fed filtered air via a parker pumper or something similar to keep the belt cool and clean to help them last. I have seen Grizzley's with as much as 6,000miles on them before changing a belt and the belt didn't actually need to be changed out. Just a thought. I don't know if I really need to go to this extent or if I ever will since I seem to get about 3 to 4 full weeks of ride time out of my belts now. Which if you ever follow me is prolly a couple thousand miles! Tom |
