98 Triple EEE http://pilotodyssey.com/PO/viewtopic.php?f=124&t=15594 |
Page 6 of 7 |
Author: | bullnerd [ Sat Apr 20, 2019 8:03 pm ] |
Post subject: | Re: 98 Triple EEE |
Congrats on the first ride! Phazer pilot is Sweet! That Phazer Engine is pretty much ideal for this size buggy, and bullet proof! |
Author: | Rppjr [ Sat Apr 20, 2019 8:46 pm ] |
Yeah, two rides in and he is talking turbo!! |
Author: | canadian oddy [ Sun Apr 21, 2019 7:50 am ] |
Rppjr wrote: Most of the late morning I was dealing with fueling problems. When I would lift off the throttle and get back on the gas it wasn’t getting fuel. I put a 230 main jet after the t going to the tank return and it dived that problem. Why put a jet in the line ?? Make a check valve: viewtopic.php?f=1&t=17885&hilit=check+valve+homemade Well off to work for me . |
Author: | Rppjr [ Sun Apr 21, 2019 3:12 pm ] |
The t fitting I have was letting all the fuel bypass. So put the jet in line to force more fuel to the carb and not lose it all going back to the tank. I will try what’s in your link. https://youtu.be/v1YK-AdcV8Y Bob |
Author: | Rppjr [ Fri Jun 07, 2019 5:40 pm ] | ||||
Post subject: | Re: 98 Triple EEE | ||||
Last trip to the dunes the intake manifold boot tore. I didn’t have a support for the carb and the air filter. I knew K&N made one with a stud on the end so it could be supported but didn’t really want to go that route. Ended up searching Uni filters sight and they make one as well. It only comes with a 3” opening on the carb side so I picked up a rubber spacer, their filter assembly and finally a replacement Mikuni rubber intake boot. Made a simple bracket from the top of the trans to the filter.
Author: | go oddy [ Fri Jun 07, 2019 6:00 pm ] |
Very nice! Part number for filter and reduced if you could please. |
Author: | Rppjr [ Fri Jun 07, 2019 7:01 pm ] | ||
https://unifilter.com/online-catalog/au ... e-filters/ Unused the UAP-6300 6” long filter with 3” opening. They make longer filters with larger diameter openings as well. The spacer/adapter was just some silicone turbo hose that a local speed shop gave me a piece of from some used ones in a bin (sorry no part number). Bob
Author: | go oddy [ Fri Jun 07, 2019 8:48 pm ] |
Thanks very much.. |
Author: | Rppjr [ Mon Jun 10, 2019 11:39 pm ] | |||
Was going over the buggy and found this broken tab. So figured I would pull the pipe and have the finish redone since it burned all the high temp paint off. There is no airflow with the heat shield blocking there. After pulling the seat I noticed the crack in the pipe by the exhaust port. This pipe has been through quite a bit. It broke once before in this area and was repaired. It is a Power Pros pipe and was originally the 2 piece style but somewhere along the way somebody welded it as one piece. So... could the cracking problem be it is welded as one piece now? The motor (( Internal Combustion Engine ? )) is rubber mounted as well as the pipe and silencer. Maybe just excessive heat or? I have a Power Pros 2 piece pipe for a pilot that exits the left side, I could have someone take the 2 pipes and make one good one out of it. I hate to cut up a decent pipe though. Bob
Author: | canadian oddy [ Tue Jun 11, 2019 12:24 am ] |
Those two cracks tell me that there is a tremendous amount of vibration there. If it was just one crack then maybe I would give it metal fatigue but not two. That second one is really telling the story to me. What condition are you Engine mounts in ?? Worn out and shot ?? CO |
Author: | Rppjr [ Tue Jun 11, 2019 7:16 am ] |
The Engine mounts looked to be in very good condition. No cracking, no missing rubber, they even fit snug. I bought a couple sets, they are used and 25+ years old so who knows. Bob |
Author: | Rppjr [ Sat Jul 20, 2019 2:27 pm ] | ||||
I picked up these wheels and tires awhile ago and the plan was to use them in place of the Champion wheels. They are Hiper 12” Carbon Fiber wheels with the Polaris 4x156 bolt pattern. I had a place make the conversion from 4x130 to 4x156. The front adapters are 1 1/4” thick while the rears will only be 1”. Front spacers ended up narrowing the front track 1/2” on each side with the different off set of the wheel even with the spacer. The rears will be wider at about 1 more on each side again with the offset of the wheel.. The tires that came with the wheels are a Kenda K585 25-8-12 front and 25-10-12 rear. Weight wise they are comparable to the champion rims and steel belted BF Goodrich 185/70/13 tires. The kendas are an 8 ply tire so with only a couple pounds of air in them they don’t even look flat. The Triple E is considerably less than a Polaris RZR so they tires are likely overkill. the orange bead lock rings will get replaced or painted with a different color.
Author: | Rppjr [ Thu Oct 31, 2019 12:07 pm ] | ||
So the power pros pipe on the right I’m going to have converted to a right side exit. That will be easier at the moment. The original pipe someone welded the two pieces as one and it was cracked when I got it. Cracked again after 2 trips out. Eventually it will be modified back to the way it was and used as a spare. Finally broke down and bought the other two wheel adapters so all 4 will be the Hiper wheels and Kenda tires.
Author: | Rppjr [ Tue Feb 25, 2020 2:04 pm ] | ||||||
Post subject: | Re: 98 Triple EEE | ||||||
Rusty came to Vegas over last weekend, I had given him the cracked pipe to repair. He brought it back as well as his welder. Converted a pipe I bought from redskinman from left to right side exit. Here are a few pics. Pipe fits well and we ended up up with more room between the fuel filler, roll over/return line, radiator hose. Still needs to be cleaned up and painted/chromed.
Author: | canadian oddy [ Tue Feb 25, 2020 3:05 pm ] |
Goddamn that thing is gona be loud . CO |
Author: | Kuma [ Tue Feb 25, 2020 4:32 pm ] |
loud is all relative, compares to a top fueler that will be quiet |
Author: | Rppjr [ Tue Feb 25, 2020 9:02 pm ] |
It’s quite a bit louder than the old setup, I’m going to repack and run with it. Look for a US forest service approved spark insert for it. They are crazy about that now. Bob |
Author: | bullnerd [ Tue Feb 25, 2020 10:17 pm ] |
I thought Russ had more hair than that! |
Author: | Rppjr [ Tue Feb 25, 2020 10:54 pm ] |
Nope, bald as a ping pong ball. Hahaha |
Author: | canadian oddy [ Wed Feb 26, 2020 12:39 am ] | |||||
Rppjr wrote: It’s quite a bit louder than the old setup, I’m going to repack and run with it. Look for a US forest service approved spark insert for it. They are crazy about that now. Bob No problem. Make a "spark arrester" and stamp the necessary numbers in it yourself . Something like this with those #'s and lettering. Who's gona know ?? CO
Author: | Rppjr [ Sat Mar 14, 2020 8:42 pm ] | ||||
CO I have one like that, after seeing your picture I went and dug through a bunch of boxes and found it. I bought this kit on eBay to convert the manual choke on the carb to a cable actuated one. Purchased a Choke cable and mounted it on the “dash” above the steering column. Now It can warmed up while belting in. Cool setup.
Author: | Rppjr [ Sat Aug 08, 2020 9:30 pm ] | ||
Well, it’s been forever but I believe I’m done with this. Here is a pic of the Engine bay. I am trading some stuff to a friend who does polish and chrome work. So I had the pipe/silencer chromed and the belt guard polished. Biggest things I learned from this build are #1. Old specialty buggies are a pain in the ass for parts. The Time:money involved in Reproducing parts (some just from pictures) is ridiculous. #2, pre assemble everything before you powder coat/paint/chrome/polish/etc. here is a picture of the Engine area. I will post up some more final picks, when I can get it out and drive it. Bob
Author: | adnoh [ Sun Aug 09, 2020 8:23 pm ] |
Looks really nice. Thanks for sharing the build |
Author: | bugeye59 [ Mon Aug 10, 2020 7:33 am ] |
Well done Bob.Your passion got you thru. Unbuggylievable! |
Author: | Kuma [ Mon Aug 10, 2020 2:09 pm ] |
very nice, hope to see some of these in person next season. |
Page 6 of 7 | All times are UTC - 5 hours [ DST ] |
