well here it is, done as far as im going too for now.Not a professional job by any means but for a week and some praypaint ,it came out pretty nice.From what was going to be a easy radious arm exchange turned out to be a major project.I didnt take it all apart but did take the cage off and radious arms were taken apart ,tank was removed but taped & covered most of the rest.Front suspension was loosened taped and painted.brackets bolts and nuts were removed and painted either by hand or spray.Heres a few specs for those that arent familiar with mine. New cases ,crank,rod,80mm wiesco,cylinder-new
motor ((
Internal Combustion Engine ? )) all the way through with oil balancer mod,pilot intake with v-force reeds & spacer plate,39mm pwk keihn carb,power pros pipe,Kustom Kraft water cooled head,Egt gauge,newer axles,bearings,brakes,Works shocks front and rear,banshee radiator,precision engineering front bumper(dave slifka),seat cover by Odyknuck,oil balancer vent mod,comet clutches front and rear and ready for the ice
im sure theres something im forgetting but hey happy new year!
Attachments: |
