It is currently Wed May 08, 2024 6:52 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Base gasket?
PostPosted: Sun Nov 19, 2017 11:19 pm
Johnnyp23 wrote:
Is that good or bad. Reading the caliper i think its a 3.095
Read my statement above yours here :-)
PostPosted: Sun Nov 19, 2017 11:22 pm
In my opinion fully called it.
Slam it back together with a metal base gasket and some red high temp silicone and call it a day.
You probably didn't do a pressure test BEFORE you took it apart so now you don't know if your seals are good on the crank. Put it together and pressure/vacuum test it.
PostPosted: Sun Nov 19, 2017 11:30 pm
Where all do i put the silicone?
PostPosted: Sun Nov 19, 2017 11:32 pm
use very little, you don't need much, put a thin layer on the metal base gasket to help seal the cylinder
PostPosted: Sun Nov 19, 2017 11:34 pm
Top and bottom of the gasket?
PostPosted: Sun Nov 19, 2017 11:36 pm
yes
PostPosted: Sun Nov 19, 2017 11:49 pm
On a positive note here, that is a near new original cylinder.
That means you can (if you ever have to) bore it to 80mm - 80.5mm - 81mm - 81.5mm - 82mm which is the max. In other words that Engine will out live you no matter how old you are right now. You have five over bores left on that thing.
If you run AVGAS :-) or high octane gas that Engine will run forever.
A word of caution here. Nothing will save you if the Engine is not sealed (no leaks). That's why we pressure test them BEFORE we install them. Below is a pdf on pressure testing a two smoke.
Also the original intakes are as hard as the back of gods head now after 30+ years. They develop cracks just looking at them and that is a leak. Inspect yours very very close. When you pressure test, do it with that rubber intake on the Engine. Don't use a block off plate.
Downloaded 47 times
PostPosted: Sun Nov 19, 2017 11:50 pm
Does it mean my rings are bad if I can compress them easily one way but if I flip them over they are much harder. I do realize the gap only goes in the one spot but don't know if rings are made different for one side up
PostPosted: Sun Nov 19, 2017 11:54 pm
That don't sound right to me. The piston has pins in the ring lands. Are you sure you didn't accidently have the ring over one of those pins ??
Yes there are cases where rings should go only facing one way but I don't think that is the case with an oddy. And even if it was, it shouldN't make a difference on spring pressure.
PostPosted: Sun Nov 19, 2017 11:57 pm
I think they are warped a little
When you put it together, WATCH IT. The cylinder should slide down to the casing easily. NO HAMMERS.
What happens is the ring will slip out of its position and get hung up.
If the cylinder don't slide down easily that is your warning to pull it off and try again. Don't get rammy.
PostPosted: Mon Nov 20, 2017 12:00 am
:shock: :shock: I find that hard to believe. Show me a picture - I call bull shyte.
PostPosted: Mon Nov 20, 2017 12:03 am
Double and triple checked. Both top and bottom ring only fit good one way
PostPosted: Mon Nov 20, 2017 12:09 am
Bullshyte you say. Lol
File comment: Wont go in all the way
File comment: Perfect fit i think
Well maybe I just learned something new about these oddys.
I don't have much experience with an ART piston. I did own one at one time but it was on a parts Engine that I bought.
Put it together the way you feel is correct. Follow your instincts.
PostPosted: Mon Nov 20, 2017 12:12 am
One way spins freely the other way binds as i turn it
PostPosted: Mon Nov 20, 2017 12:14 am
Earlier in this post I posted a link to two threads. When you get time please read them. There is some pics of two blown base gaskets and other info.
I also notice you are rebuilding and taking pics of this thing in your kitchen. Your wife is gona cut your balls off if you scratch the kitchen table up.
PostPosted: Mon Nov 20, 2017 12:21 am
Your a new guy here so welcome.
Below is some important info. Dis-regard it at your own risk.
It was learned at great cost.
Here is my list of things to check on an oddy when you are doing an Engine job or bought one.
9) Remove the drive shafts and make sure the u joints are good and grease the splines.
10) Check the wheel bearings.
14) Must build shock savers. viewtopic.php?f=1&t=15745&hilit=shock+saver+chain
15) Replace the rear springs with 155lbs units. Stock ones are way to stiff.
16) Some good info here: viewtopic.php?f=26&t=15392&hilit=danifold
And here: viewtopic.php?f=5&t=17468
PostPosted: Mon Nov 20, 2017 12:26 am
Thanks CO and everyone else you've been a great help. Il keep ya posted on the improvements. Maybe we can go for a ride someday. I have a few friends in bellingham!
PostPosted: Mon Nov 20, 2017 8:02 pm
Oh my. The arts stock pistons have tapered rings. Refer to the manual for reference 6-7
Flat on bottom tapered on top.
PostPosted: Wed Nov 22, 2017 12:04 am
Ok folks, I have an original fuel pump and was getting 1/4 cup every 10 seconds. If my math is correct that is 2oz. I bought a new mikuni pump and am still getting about 2oz. When i blow back down the pulse line i can tell a major difference piston positions but even when I presume the piston is all the way down I fill up my mouth with air and with pressure it bleeds off in a few seconds. Is that normal or do I have a leak somewhere? Thanks again for the help guys.
PostPosted: Wed Nov 22, 2017 1:21 am
1) You can try the pump test again by having the main line hooked to the carb and the return line pumping into the cup. I know one member here who had that same issue as you with a new pump and used the return line.
2) You might be real good a blowing but that don't work. Blow/Pressure test the correct way. :-)
PostPosted: Sun Nov 26, 2017 2:55 pm
I found these rings. Do you think they would work?
https://www.ebay.com/i/122210645117?chn ... 5712551285
PostPosted: Sun Nov 26, 2017 2:57 pm
The ring look identical
PostPosted: Sun Nov 26, 2017 3:50 pm
There is no way to tell if those rings are correct unless you are holding them in your hand.
Those egay pictures mean nothing. They could be pictures of anything just posted there.
Below is an item I got from the manual that adnoh was talking about earlier in this post about the rings.
Notice the taper that he was talking about.
Registered users: Bing [Bot], Google [Bot], Lanix, Rppjr
