Lonerider wrote:
I have a 2007 toyota tundra with 50,000 miles. Yes, low mileage as I really only drive it during the winter.
I have a question for all those that live in the midwest or areas that use salt for the ice in the winter time. Is there any undercoating that can be used or shops that could be recommended in order to reduce any rust on the chassis of my truck? I have heard of various products (wool wax, 3m undercoating, etc.), but am hearing and reading mixed reviews.
Appreciate any thoughts or recommendations.
Hey long time no see!
Go to YouTube and search for home made rust proofing or DYI rust proofing to get some ideas
The best I found over the years was Plow Coat I got from Farm and Fleet. I mixed it really good with a power mixer on a drill then poured it in a pressure pot sprayer and sprayed the entire underside of the frame and body, do not do the
Engine trans exhaust etc.
MIX IT GOOD all the solids are on the bottom and its hard to get them back into suspension. If you go with plow coat spray outside in the grass its about impossible to get off concrete! Also wear cloths your going to throw away or double layer bunny suits, and a stocking cap to protect the hair.... Its a messy process.
Last I looked they wanted 50 bux a gallon for Plow Coat at Farm and Fleet, the last time I bought it years ago it was 10 bux a gallon. Search online see what the farmers are using today.
Then there is Ziebart they have the best system going but its expensive.
https://www.ziebart.com/auto-care-servi ... n-services.
Isn't the Toyota Tundra the one that last 300k + miles and really reliable? If it is, its probably worth the investment ,as it will probably rust out before you wear it out.
Also check out Scotty Kilmer on YouTube see what he says.
https://www.youtube.com/@scottykilmerGood seeing you again!
NOTHING I have ever tried in a spray can you buy at retail stores has ever worked, spray it on and its gone in a year.
Let us know what you find, run across any interesting or promising links drop them here I need to do my vehicles, salt is coming soon!
