It is currently Thu May 02, 2024 8:07 am
 Post subject: Rear disc brake pads
PostPosted: Sun Jul 07, 2019 8:40 am
I tried doing a search but to no avail....
I see there are at least a couple of different rear disc brake pads available for the Pilot. Anyone have a preference on a good set of pads to use/get?
 Post subject: Re: Rear disc brake pads
PostPosted: Wed Jul 10, 2019 7:54 pm
Anything but the cheap no name pads sold on ebay will probably work great for you. I prefer EBC pads. I think the sintered pads are closer to stock. They have a carbon pad as well that doesnt hold the heat as much but they wear quite a bit quicker.
PostPosted: Thu Jul 11, 2019 6:36 am
Thanks for posting. Then I’ll probably pick up the EBC FA111R. The sintered iron pads. Even if they wear a little quicker but get rid of the heat better will be fine for me. I’m not hard on the brakes on the type of riding that I’m doing.
Later, SB4x4
