It is currently Mon May 20, 2024 4:03 pm
 Post subject: Fl350 Fuel Lines Routing
PostPosted: Fri Mar 20, 2015 1:55 pm
Ok guys, so my Engine cylinder work is being done at the moment. I got my fuel pump in the mail. I ordered the mikuni pump.
Can someone diagram out better than the manual how I'm suppose to route and hook up all the different lines and what kind of fuel line should I use.
What kind of line should I use coming off the Engine by the clutch?
I have the 3 way valve, new fuel pump, and correct fuel filter and carb to route all the hoses to.
Should have everything ready to rock and roll by next weekend.
Just waiting on two new crank seals and side cover gaskets.
Thank You.
PostPosted: Fri Mar 20, 2015 2:09 pm
You can use the PilotOdyssey.com Google Search link then click on "Pictures" and narrow your search quickly https://www.google.com/search?q=Fuel+Li ... CAYQ_AUoAQ
Then click on the pictures to see the post on these forums that contains the pics. like this one https://www.google.com/search?q=Fuel+Li ... B742%3B568
Then it takes you to this page viewtopic.php?f=5&t=13931
Pretty cool huh.
ALSO after you create you post look at the bottom of the page after you submit your post automatically shows other post related to the one you just created look at the second one on the list. Sometimes you can even answer your own questions :-)
