It is currently Sun May 12, 2024 7:54 pm
PostPosted: Mon Dec 07, 2020 2:26 pm
Is the ball joints on the front suspension trailing arms replaceable? None have any play in them except for one. i was considering drilling it out of the spindle (previous owner either stripped the threads or broke them off because the it is welded onto the spindle) and then putting a new ball joint onto the arm but before i want to make sure i am able to do so. Honda i believe has them labeled as 1 part number for both the arm and ball joint. If they are un replaceable could i drill them out and make a new hole to hold a new ball joint?
PostPosted: Mon Dec 07, 2020 2:57 pm
Is this for pilot or Odyssey?
assuming Odyssey and I have no answer, the pilot is not replaceable, replace the a arm or do a modification to accept quad ball joints.
PostPosted: Mon Dec 07, 2020 3:00 pm
Its for the fl350
PostPosted: Mon Dec 07, 2020 4:02 pm
Read this thread I did: viewtopic.php?f=1&t=17888&hilit=ball+joint
Registered users: Bing [Bot], Google [Bot], Gootjr, Lanix
