Comet Duster Clutch and Driven Help http://pilotodyssey.com/PO/viewtopic.php?f=28&t=19693 |
Page 1 of 1 |
Author: | Morecubes Mike [ Tue Feb 18, 2020 7:09 am ] | |||
Post subject: | Comet Duster Clutch and Driven Help | |||
So I bought a FL250 and it wants to drive even at idle. I thought the belt was wrong as it seems too wide for the driven pulleys but turns out I have a duster clutch ch which needs the wide belt. So Amongst the pile of parts that came with it is a driven pulley that’s smaller in diameter and is wider so I’m thinking this is the pulley that should be used with the duster clutch. I’m looking for conformation before I spend and time cleaning it up and fitting it, possible it is damaged and was swapped out for that reason Attachment: D8AEC7E1-C379-46A3-AC3E-C8B01D90019B.jpeg [ 73.62 KiB | Viewed 23417 times ]
Author: | Morecubes Mike [ Tue Feb 18, 2020 9:31 pm ] |
Post subject: | Re: Comet Duster Clutch and Driven Help |
Can someone with a duster setup measure there driven pulley diameter so I can compare to the pulley I have sitting here |
Author: | fully [ Wed Feb 19, 2020 11:10 pm ] |
that belt looks to wide, it should fit flush with the driven clutch |
Author: | Morecubes Mike [ Thu Feb 20, 2020 9:03 am ] |
That’s because it’s the wrong driven pulley I’m trying to find info on what I should be running |
Author: | canadian oddy [ Tue Feb 25, 2020 2:58 pm ] |
Morecubes Mike wrote: That’s because it’s the wrong driven pulley I’m trying to find info on what I should be running I don't know if this will help you, but on an oddy FL350 the driven pulley is 8 1/2" in diameter. The stock FL350 driven is a 90D Salsbury. I see that you have an FL250 but all my machines are FL350's. Hope this helps. CO |
