It is currently Thu May 09, 2024 5:06 pm
PostPosted: Wed May 09, 2012 4:17 pm
Last week when Tspreed came over he dropped off a FL250 bottom end that murph4478 gave me wanted to see if I could do something with it, I will let him fill in the history of this Engine but I am pretty sure it was part of his project 340 swap project found here viewtopic.php?t=9584
Typical FL350 bottom end, many years of grease oil dirt everyplace, someone removed the top end then naturally they didnt pour oil in the bottom end and then cover it up or put into a plastic bag so its all rusted up.
Their is end play on the crank shaft so their is clearance between the crank and the inner race of the bearings or clearance between the outer race and the cases, this is a common problem with a FL250 Engine and easily fixed.
File comment: .
Rust
PostPosted: Wed May 09, 2012 4:21 pm
Flywheel still installed, naturally someone tried to remove the flywheel and got all caveman on it, the end of the crankshaft is all mushroomed up, they screwed up the threads where the flywheel puller goes I had to take a grinder and grind out the damaged area of the threads to install my puller and pull the flywheel.
Arrows point to the damage threads.
PostPosted: Wed May 09, 2012 4:22 pm
Once the threads were repaired the puller installed the flywheel came right off with no effort at all.
PostPosted: Wed May 09, 2012 4:25 pm
Next the stator plate needs removed.
The first thing you need to do before even thinking about trying to remove the 3 screws is to take a long flat punch and tap the heads of the screws really hard 2-3 times each then take a proper fitting quality screwdriver and smack them again with a hammer and using the screw driver.
These 3 came out without the use of my impact, a good smack on the heads of these screws works 99% of the time.
PostPosted: Wed May 09, 2012 4:26 pm
Stator removed time to clean the Engine.
File comment: .
All 3 screws stuck to the magnet for safe keeping
PostPosted: Wed May 09, 2012 4:52 pm
Engine cleaned, dried, PB Blaster put on the studs and is currently soaking.
While it soaks I will continue on with other projects I need to focus on, I have seen enough and know what parts I need to order.
Parts list so far.
Complete Engine gasket kit.
Crank bearings
Rod kit.
94050-12000 Nut, Flange, 12MM get 6 for stock flywheel
90437-611-000 Washer, Plain, 12MM get 6 for stock flywheel
90701-HB6010 Key, Woodruff, 25x14x4 get 6 for stock flywheel
94601-18000 Clip, Piston Pin, 18mm get 6 for stock
91015-357-003 Bearing 1, Connecting Rod Small
13111-357-000 Pin A, Piston
13112-357-000 Pin B, Piston
91202-357-003 Oil Seal, 25x55x10 MAG side seal
91203-950-003 Oil Seal, 30x55x10 clutch side seal
Registered users: Bing [Bot], eseymour72, Google [Bot], JMBalbiani, liduno
