Squish is the clearance between the piston and the head when the piston is at top dead center.
Search the web or vintage motorcycle sites for info on the 70's Honda 250 cycle engines, the stock FL250 they used the MR250 top end the CR250 top end made more HP and torque I forget how much more but it was significant enough it was very noticeable by seat of the pants.
I will research on how to check the squish and then take the heads off. My buddy next door can help me measure if needed.
If this is not a big bore kit could I go with my original plan and just swap bottom ends?
Also you posted above
"If that Engine was run before as assembled I would op to have the crank repaired by speedchaser then the pin welded, my guess is its twisted on the rod pin and not bent."Yes I did start the Engine when I first got it home in the buggy. I saw it was bent like that and stop it right away. This Engine was in the car but the car also came with nice spare Engine that I used. My guess is the damage happend right away. If you look at the top end it is like brand new. You can still see the hone or machine marks on the cylinder. The PO who sold it to the guy I bought it from (could be more PO) said it was a big bore. Or I think that's what he was saying. He said when he had it was not rebuilt with new piston like it has now. So it was rebuilt and perhaps not done right and something happend right away with the crank. Or they rebuilt it and somthing came up into the belt with fresh
motor ((
Internal Combustion Engine ? )).
Here is some CSI fron past owner. As you can see someone rebuilt it after he sold it.
hey this is Andy
Nice to see that odyssey shown some love. I used to own that back in 08 or around then. I loved it. Looks like you really went through it. I sold it for a steal of a deal to someone. I sure know it's the same one because I built that air filter set up with a napa filter and shop vac hose. Made the bracket it hangs from and all. I did a lot of work on that thing my self. When I had it I had to redo all the points because it shelled out and ran terrible. Thought at first it was a fuel issue but it ended up being that the points were bad. I know what you mean about a low center of gravity. That thing could whip nuts like crazy. On pavement too. So after all this time was the Engine bad? Is that why you redid the top end? Sure was really peppy having the big bore kit. I don't think i'd ever go back to a standard 250 odyssey. Did you put a new back axle? I remember when I got it that it was pretty bent but it still ran really good. kind of made a wump wump sound when running fast on pavement. I sure went through the starters too. The flanges on the mounting holes are way too weak.
Well thanks for bringing back some good memories. Would be awesome to hear back.Can you tell me any work you did inside the original Engine? Looks to be brand new but somehow the crank got bent really bad. I also switched over to
CDI (Capacitor Discharge Ignition) and ditched the points as I do on all my ody's.
Hey. I honestly didn't do any work on the inside of an Engine. I had a guy I know do the points. I was running like crap and I tried everything. looked like it had good spark so I thought it wasn't an issue he pulled it apart and found out the points were bad. Crank was never bent when I had it. The fellow that I sold it to was from castle rock. His son actually bought it. They may have went through the Engine. I do have to say CDI (Capacitor Discharge Ignition) seems like a way better set up. That elsinore is bored over too isn't it.? That's a big bore kit. That air filter set up I put on it was to replace the cone filter that was hanging off the carb like standard. It kept falling off from bouncing so I set it up nice and solid and kept it from getting wet in the mud and such. Used to actually be up by the back of the seat on the right side. It was too loud so I shortened it and made the bracket between the frame in the back. So I what I am thinking is he does not really know if it is a big bore kit for sure. This weekend I will take the head off and go from there.
This is the car the Engine came in and what car the guy above is talking about. This is my wifes car. She liked the blue and has super safe feeling cage.
