It is currently Fri May 10, 2024 2:25 am
PostPosted: Tue Aug 07, 2012 9:56 pm
i have a fl250 that will start and idle fine but when you give it gas it bogs bad and blow gas out the back of the carb. i have tryed 2 different carbs that work great on my other fl250 an a new coil new plug new CDI (Capacitor Discharge Ignition) it is getting fuel the pump works great. i have noticed that it seems to have a weak spark. i think it might be my stator but not sure how how to test it or if that would even be my problem also the head light an tail light have are getting no power. this was a points Engine that i changed over to CDI (Capacitor Discharge Ignition) but as far as i no that shoud not matter i put the CDI (Capacitor Discharge Ignition) stator and fly wheel on and it sparks but weak am i missing something?? if any one can help me out please let me no thanks
PostPosted: Tue Aug 07, 2012 10:22 pm
Try swapping in a different fuel bypass t. If your T is clogged.. overflow gas will be forced into the carb
PostPosted: Wed Aug 08, 2012 7:26 pm
it was cloged but i already changed it you can take of the fuel cap and see the fuel coming back into the the tank but it still does the same thing
PostPosted: Thu Aug 09, 2012 9:26 pm
Have you checked to see if your muffler is stopped up?
PostPosted: Fri Aug 10, 2012 8:08 am
Quick check, unscrew the spark plug cap from the spark plug then cut off about 1/4" of the wire and screw it back on also check all the electrical connections including grounds bad connections contribute to weak spark.
Also try a plug out of the other machines the carbs work good on.
PostPosted: Fri Aug 10, 2012 11:40 pm
yes their was a mouse nest in it but i cleaned it all out but it still did the same thing i found that the wires from the stator were all almost turned to dust and white inside the plastic so i justed replaced the wires and im going to try ageain tomarrow but thanks for the advice
PostPosted: Fri Aug 10, 2012 11:45 pm
i hope i found the problem the wires form the stator were all coroded (im not a good speller so don't judge me) so i just replaced them all so im going to try them tomarrow but thanks for the help. and i don't think its the coil cause it is brand new and it also works fine on the other 250
PostPosted: Sat Aug 11, 2012 8:01 pm
Please let us know what you figure out.
PostPosted: Fri Feb 08, 2013 2:45 pm
Ever figure it out?
Registered users: Bing [Bot], canadian oddy, chorizofingers, Google [Bot], Gootjr
