dlumpy5282 wrote:
I have 2 fl250s one runs great i got another guy changed cylinder and piston when I got would not crank pull starter and it pulled easy. Removed starter bolt and the guy did not put flywheel nut on so it sheered key and was just spinning , I replaced key and nut and tried to start. when I pull rope it has some resistance like a little compression but not alot and nothing like the one that runs. after seeing what the guy had done with flywheel figured best to check cylinder and piston I did find 1 piston pin clip missing and will be taking cylinder and piston to machine shop to get measurements
Ahh ok, yeah after finding the lose nut and the missing cir clip I would inspect everything real close, let us know what you find.
After you fixed the flywheel you had spark?
