It is currently Thu May 09, 2024 5:43 pm
 Post subject: cheap kill switch
PostPosted: Sun Oct 14, 2012 5:32 pm
not sure if this has been addressed but i needed a kill switch for my fl250
checking on ebay I found many at 170.00 or more new
after some research I found that a atc70 switch can work
I found one on ebay for 26.00 and got it and its the same except wires different length and easy just to solder wires in or butt connectors
hope this can help someone
 Post subject: Re: cheap kill switch
PostPosted: Mon Oct 15, 2012 11:01 am
There are several assys for headlight and kill switches that will work from HONDA. You can find them NOS very easily if you look.
I'm a big fan of using NOS parts when you can afford to, but $170 is price gouging. Good wire is not costly and you can put any pigtail on it you like for cheap. The FL250 ones are being repopped as we speak from an Odyssey enthusiest up north and should be available soon. I hope they are similar in cost to what HONDA charged or charges.
Can you tell that my kill switch assy had a different part number than the ones listed for FL250 models? I can't.
Registered users: Bing [Bot], eseymour72, Google [Bot], liduno
