It is currently Sat Jun 22, 2024 6:51 am
PostPosted: Thu Mar 01, 2012 5:54 pm
Sorry for the long post but...
I'm replacing the tie rods on my 2 odys and am having a bastard of a time getting them to function correctly. I'm looking for any advice to help me in the adjustment process, mainly centering the wheels. I ordered OEM tie rods so you wouldn't think it would be so hard! I've read a million websites about camber/toe etc. but that is not my issue.
I can't seem to get both wheels to turn together correctly, one is fine on its own but when both are connected one always seems to be holding the other back. I think I've tried every adjustment possible in turning the threaded rods in/out but it still sucks. Furthermore, when I have it jacked up in the air to adjust it looks like its turning fine, but when its on the ground driving around it turns very poorly. Please let me know if you have any thoughts or advice. Many thanks! Pics to follow
PostPosted: Mon Sep 17, 2012 8:53 pm
hey im niko and im sorry this is way later but i have the same problem and what i red is you have to take the turn stops off or grind them down hope it helps
PostPosted: Sun Dec 30, 2012 3:56 pm
Im having a problem with them too. I cant get it to turn unless i use alot of force then they click out but other then that they bearly turn
