FL250 Radiator help http://pilotodyssey.com/PO/viewtopic.php?f=31&t=17508 |
Page 1 of 1 |
Author: | wjstarck [ Sat Jul 15, 2017 11:58 am ] |
Post subject: | FL250 Radiator help |
Hello- I picked up a radiator from an FL400 to use with the water cooled head on my FL250. Attachment: radiatorback.jpg [ 42.59 KiB | Viewed 4850 times ] I was trying to see if I could get the fan to spin up by connecting it the tail light wires but it wouldn't spin. I can get the fan to spin up if I connect the fan motor (( Internal Combustion Engine ? )) directly to the battery, so I know the fan motor (( Internal Combustion Engine ? )) is good. Any suggestions on how to wire this in? How about the fan connector - any source for that or will I have to find someone trying to part it out? I looked at a few Pilot wiring harnesses for sale on eBay but didn't see that connector unless I missed it. Attachment: connectorinside.jpg [ 29.98 KiB | Viewed 4850 times ] Attachment: radiatorconnector1.jpg [ 30.4 KiB | Viewed 4850 times ] Does anyone know what these connections on the bottom of the radiator are for? Attachment: radiatorconnectorsback.jpg [ 34.86 KiB | Viewed 4850 times ] |
Author: | canadian oddy [ Sat Jul 15, 2017 12:35 pm ] | ||
Post subject: | Re: FL250 Radiator help | ||
Here is a 90' Pilot wiring diagram if it will help. As for a fan connector I think you will have trouble finding that. I wouldn't cut the original connector off because you do have a valuable rad there. I would just use stakon connectors on the end of the wires your going to attach and then tape securely.
Author: | canadian oddy [ Sat Jul 15, 2017 12:41 pm ] |
If that sensor in the rad is not in water that is at high temp it won't trigger the fan to come on. Remove it and put it in boiling water while it is all hooked up. |
Author: | canadian oddy [ Sat Jul 15, 2017 12:45 pm ] |
I bet rmesser would do a selfie kissing ur bum if he could get his hands on that rad right now. |
Author: | wjstarck [ Sat Jul 15, 2017 12:54 pm ] |
canadian oddy wrote: If that sensor in the rad is not in water that is at high temp it won't trigger the fan to come on. Remove it and put it in boiling water while it is all hooked up. Thanks. You mean the one with the two green wires going into the back of the radiator? |
Author: | canadian oddy [ Sat Jul 15, 2017 1:26 pm ] |
wjstarck wrote: canadian oddy wrote: If that sensor in the rad is not in water that is at high temp it won't trigger the fan to come on. Remove it and put it in boiling water while it is all hooked up. Thanks. You mean the one with the two green wires going into the back of the radiator? I am a terrible electrician, I hate that trade. I would say yes put that one in the boiling water. Check the pdf wiring diagram. The one wire sensor is probably for the temp gauge. |
Author: | canadian oddy [ Sat Jul 15, 2017 1:35 pm ] |
I am thinking: 1) positive from battery to fan 2) fan to a sensor wire 3) other sensor wire to negative on battery Once the water boils it should trigger the fan. If I am wrong I hope others chime in here. |
Author: | FloridaEdd [ Sat Jul 15, 2017 2:19 pm ] |
You can put the sensor in a pot of hot water with a thermometer in there. Take a voltage meter and set it connuitity ,you connect one probe to each wire and when it triggers ur voltage meter will beep. Check the thermometer to see at what temp it operated. To avoid cutting the plug use spade connectors to connect the fan and with a q tip lightly coat the inside of the connector with petrolieum jelly and fill with silacone. This will keep the connections weather proof but the pateolieum jelly will make the silacone release easy. |
Author: | FloridaEdd [ Sat Jul 15, 2017 2:24 pm ] |
The single wire sensor is for a temp warning light that u can test the same as above but put a probe on the spade connector and the other on the body of the sensor too see what temp it comes on at. |
Author: | wjstarck [ Sat Jul 15, 2017 4:27 pm ] |
OK, thanks guys that sounds correct. I connected it as you suggested but sadly the sensor does not trigger the fan when placed in a cup of boiling water. Bad sensor methinks, I wonder if that temp sensor might be standard across Hondas so I could find a replacement? |
Author: | hoser [ Sat Jul 15, 2017 4:31 pm ] |
All you need on a FL250 with a LC head is a Banshee radiator no fan no water pump. http://www.pilotodyssey.com/challenger.htm https://www.google.com/search?q=banshee ... r&tbm=shop |
Author: | rmesser [ Sat Jul 15, 2017 4:41 pm ] |
hoser wrote: All you need on a FL250 with a LC head is a Banshee radiator no fan no water pump. http://www.pilotodyssey.com/challenger.htm https://www.google.com/search?q=banshee ... r&tbm=shop I 2nd that. http://www.ebay.com/itm/ATV-2ROW-ALUMIN ... x2&vxp=mtr |
Author: | FloridaEdd [ Sat Jul 15, 2017 5:46 pm ] |
Are u sure the water is heated enough? |
Author: | canadian oddy [ Sat Jul 15, 2017 6:05 pm ] |
FloridaEdd wrote: Are u sure the water is heated enough? That's what I was thinking too. If he boiled that cup on the stove in the house and then went out to the shop it ain't gona be hot enough by the time he gets there, and it takes a while to heat up all that brass too. |
Author: | wjstarck [ Sat Jul 15, 2017 6:11 pm ] |
Propane torch? |
Author: | canadian oddy [ Sat Jul 15, 2017 6:27 pm ] |
wjstarck wrote: Propane torch? In my opinion NO You don't know how much heat you putting on that sensor and next thing you know you have screwed it. Propane torch a metal cup with water in it -- YES |
Author: | wjstarck [ Sat Jul 15, 2017 7:14 pm ] |
canadian oddy wrote: wjstarck wrote: Propane torch? In my opinion NO You don't know how much heat you putting on that sensor and next thing you know you have screwed it. Propane torch a metal cup with water in it -- YES Ahhh brilliant! Never would have thought to do that lol |
Author: | wjstarck [ Sun Jul 16, 2017 7:50 pm ] |
Well, I tried the sensor-in-boiling-water trick. No go. Figuring the sensor was toast, and I had nothing to lose, I barely touched the propane flame to the end of the sensor and the fan fired right up. It ran until I put the sensor in a cup of cool water. I think that sensor should come on at 175 F, so maybe it's fried. |
Author: | canadian oddy [ Sun Jul 16, 2017 11:02 pm ] |
wjstarck wrote: Well, I tried the sensor-in-boiling-water trick. No go. Figuring the sensor was toast, and I had nothing to lose, I barely touched the propane flame to the end of the sensor and the fan fired right up. It ran until I put the sensor in a cup of cool water. I think that sensor should come on at 175 F, so maybe it's fried. Now that you have "shocked" that sensor with the blow torch I would try the water test again. You never know. Try the same water test with that other sensor that is for the high temp light. Maybe you can utilize that sensor somehow to trip a relay to start the fan. |
