Specs of muffler bolt http://pilotodyssey.com/PO/viewtopic.php?f=31&t=17531 |
Page 1 of 1 |
Author: | wjstarck [ Mon Jul 31, 2017 2:42 pm ] |
Post subject: | Specs of muffler bolt |
I removed my muffler, and the bolt that bolts it to the frame has grown legs and walked off. What are the specs on that bolt? It looks to be an M10, but I've tried M10 x 1.25 and M10 x 1.50 and they won't screw in. Is it an M10 x 1.0? If so, what is the length? I looked on Partzilla but they don't have the size of that bolt since they don't have it in stock. Thanks |
Author: | canadian oddy [ Mon Jul 31, 2017 3:47 pm ] | ||
Post subject: | Re: Specs of muffler bolt | ||
Not sure which bolt you are referring too but below is pdf of the parts book. In it they give the bolt sizes. As for where to get bolts -- any machine shop or a place like Fastenal will have it.
Author: | wjstarck [ Mon Jul 31, 2017 4:01 pm ] |
It's part #96500-08016-08 8x16 flange bolt it says. It's the one that secures the muffler to the frame (right behind the seat). Thanks |
Author: | canadian oddy [ Mon Jul 31, 2017 4:12 pm ] |
wjstarck wrote: It's part #96500-08016-08 8x16 flange bolt it says. It's the one that secures the muffler to the frame (right behind the seat). Thanks Well then it's not a 10mm bolt is it ?? According to that part number it is an 8mm and 16mm long. And a standard size 8mm bolt is 1.25 pitch. https://www.boltdepot.com/fastener-info ... Pitch.aspx |
Author: | wjstarck [ Mon Jul 31, 2017 5:16 pm ] |
OK, found the problem Apparently whoever had this buggy before me had broken that bolt off. It was retapped at 3/8", so a 3/8 x 16 fit. Thanks again Attachment: MufflerBolt.jpg [ 46.16 KiB | Viewed 3992 times ] |
Author: | go oddy [ Mon Jul 31, 2017 7:05 pm ] |
wjstarck wrote: OK, found the problem Apparently whoever had this buggy before me had broken that bolt off. It was retapped at 3/8", so a 3/8 x 16 fit. Thanks again Attachment: MufflerBolt.jpg Nice head there sir |
