It is currently Fri May 10, 2024 2:53 am
 Post subject: bogg city
PostPosted: Tue Jan 17, 2012 12:37 am
Hi guys I recently got an 83 fl250 from a guy on a work trade. Took it out this weekend and it fires right up and runs strong until 3/4 to WOT (Wide Open Throttle). I messed with the jetting with dropping a few sizes and going up a few sizes with the same result. Before my trip I put in a new fuel filter, uni air filter and a new plug new fuel lines. I did the normal thing of checking all the grounds after the bogg. Its just strang. you can run all day at half to 3/4 throttle and have fun but once you hit close to wol bogg city. Felt like a rich bogg but jets didnt make a difference at all. Could it be electricle? Im havent messed with many fl250 before mostly fl350 and pilots.
 Post subject: Re: bogg city
PostPosted: Tue Jan 17, 2012 9:39 am
fl250s are known to plug up the exhaust pipe. Is your exhaust stock? It could be starting to plug up.
PostPosted: Wed Jan 18, 2012 1:03 am
its a dg pipe. Im going to pull the exhause and carb all apart and also take the pump apart and see what I find Ill post back
