It is currently Fri May 10, 2024 1:22 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Fri May 04, 2012 5:34 am
brandonsharksfan wrote:
One issue I have not been able to solve myself is my choke will not stay on. I push the lever down and it slides right back down. Is there a rubber gromit in the carb? I thought that it was the rubber boot but I think that it is there just for protection.
You have the stock 250 carb?
Going by memory I thought their was something mechanical external to the choke that held the choke in position like the arm of the lever fell into a notch or something?
You are correct sir! There's a metal arm with a catch. It was out of line.
I'm not sure if you saw the plug pics but I'm wondering if I'm running lean.
PostPosted: Fri May 04, 2012 8:01 am
Jetting looks rich to me have you seen this post yet viewtopic.php?f=9&t=870
PostPosted: Fri May 04, 2012 5:42 pm
Jetting looks rich to me have you seen this post yet viewtopic.php?f=9&t=870" ."..
That is a great thread. Lot's of knowledge!
Rich works for me! I just don't want to burn it up being lean. I need to heat cycle her a few more times and then I will dial in the carb.
I guess having a stack of plugs would be smart.
I did get side tracked though. I'm going to Pismo Memorial Weekend so I have a line of toys waiting for my attention. Yesterday my buddy dropped off a pair of Honda TRX400s that need a lot of work. They sat outside for 3 years. I just ordered $450 in parts just to get them back running.
I also have a 83 200x that it completely broken down that I would like to have ready but I doubt I will have time for it. This ATC has been apart as long as my odyssey was. Since it has been years I started the parts search and the only thing I cant find is my bolts bag! So getting it together is going to take awhile.
Registered users: Bing [Bot], canadian oddy, chorizofingers, Google [Bot], Gootjr
