Briggs "Beastie" Engine specs for calculations http://pilotodyssey.com/PO/viewtopic.php?f=32&t=9071 |
Page 1 of 1 |
Author: | Nuke Em [ Sat Apr 02, 2011 8:07 am ] | |||||||
Post subject: | Briggs "Beastie" Engine specs for calculations | |||||||
Adnoh, an educated guess is all I want or can ask for suggeted octane. don't worry about the timing, this Briggs Engine has mechanical adjustable timing and the MSD timing box too. that's a whole other ball of wax to figure out later, just going to leave it as is for now. More info to follow soon, need anything else too, let me know. stock stroke....68mm big bore....87.00mm Wiesco lightened crank piston skirt length...76.25mm piston window port(intake side)...1.50" X .25" exhaust spigot...51mm ID base spacer plate...5.60mm sleeve thickness...2.79mm head info....twin plug NKG B9ES inner dome width...69.73mm outer dome width...87.00mm inner dome volume...30ml/cc outer dome volume...12ml/cc total volume...42cc squish... .0525"-.054" squish angles...???? piston angles...???? The compression test yielded about 137-140 lbs which suprised me. I was expecting much higher. I also expected a lower CC dome. I still need to figure ring end gap and piston wall clearance(no feeler gages with me). Fresh hone and new rings might help compression, or just need to run it a bit to get them re-seated????
Author: | Nuke Em [ Sat Apr 02, 2011 8:15 am ] | ||||||
Post subject: | Re: Briggs "Beastie" Engine specs for calculations | ||||||
more pics... I added soy sauce to water for my CC measurements, so if you are smelling/thinking chineese food when riding with me, that's why! LMAO
