It is currently Tue May 21, 2024 3:02 pm
 Post subject: Pilot Rear Axle Bearing
PostPosted: Mon Jan 20, 2014 12:50 pm
91054-HC4-003BEARING, RADIAL BALL (6007) Still available from Honda, you can use any name brand quality made in Japan 6007 bearing for this make sure you get the 6007 2RS then it comes greased and sealed both sides.
http://www.partzilla.com/parts/detail/honda/HP-91054-HC4-003.html
PostPosted: Mon Jan 20, 2014 1:34 pm
Thanks hoser, bearings ordered. Ordered Nachi bearings, supposedly good Japanese-made bearings. About half the price of the Honda OEM bearings. Going to replace all 4.
PostPosted: Mon Jan 20, 2014 2:08 pm
Yeah I have had good luck with Nachi bearings in the past, replacing all 4 is a good idea you never know what kind of a beating the old bearings have been through, as you disassemble to change them feel them each step of the way you will see what I mean its hard to tell if they are bad or worn, once you have one all the way out remove the seals and grease then feel the bearing again, seals, grease, and assembled mask a lot of the wear or damage to a bearing.
PostPosted: Sun Feb 09, 2014 8:44 pm
You were right hoser. The right side bearings were a bit rough, even without removing the seals and grease. That's all the convincing I needed.
