It is currently Wed May 22, 2024 6:02 am
PostPosted: Sun Aug 27, 2017 10:54 am
cleaning my carb today it slipped off the bench and snapped off the aluminum nipple for the coolant hose. anyone have a spare you could part with? its the small plate that has the nipple with the two special torx screws holding them on. I feel like such an ass. general cleaning because of sitting for 9 months and this happens. gives me time to remove clutches and clean/adjust.
James: 8 six zero- 209- five six seven 9. text works best. have a lot of kawi and superjet stand up parts if anyone is looking
PostPosted: Sun Aug 27, 2017 11:32 am
Welcome new guy.
I think it's going to be tough finding that part.
I doubt anyone would sell this Pilot part unless they converted their machine to rotax. But all is not lost.
Did it break off flush or did the nipple just fall out ??
Is it pot metal or aluminum ??
If the nipple fell out you could JB Weld it back in. Don't laugh, my formula race car had a rotary Engine in it and the intake tubes were JB Welded into the Engine housing. Everyone did this unless they bought factory peripheral port housings -- at HUGE cost. It worked well, no issues ever.
If this is not an option because it broke off flush is it possible to drill and tap ?? Make a new nipple with threads.
Not sure what your mechanical skill set is but that's what I would do.
Edit: If there is still a piece sticking out then you could take a piece of break line that fits over it and JB weld it on. Flare the other end of the brake line first.
Hope this helps out.
PostPosted: Sun Aug 27, 2017 6:23 pm
Let me check one of my parts boxes, I think I have the set I took off my stock carb.
Bob
PostPosted: Mon Aug 28, 2017 6:56 am
thanks guys. if rppjr cant find one ill drill and tap shouldn't be that bad...
PostPosted: Mon Aug 28, 2017 12:06 pm
do ypu need the single nipple or double nipple side, or both?
check your pm's
Bob
PostPosted: Mon Aug 28, 2017 12:12 pm
Here are some pics to make sure we are talking about the same part/parts
Bob
