It is currently Fri May 17, 2024 8:04 pm
 Post subject: 1983 fl250
PostPosted: Fri May 22, 2020 10:27 am
i cant figure out how to post multiple pictures on here so heres the craigslist add, https://sandiego.craigslist.org/esd/snw ... 26263.html. so i bought this thing aa a project a few years back and never got around to doing it. It has an aftermarket pipe, leckich watercooled head, goki electric starter, worx shocks in the front and aftermarked heavy duty extended j arms. The rollcage is aftermarket and the rear end has custom made suspension. It needs a new wire harness to tie into the goki starter and switch, it needs a battery and battery box because the pull starter was abandoned. It needs new tabs for the aftermarket pipe and it needs either a stock seat to be mounted or new tabs for the razr seat that i got, and a steering wheel cover with some switches. The starter works and motor (( Internal Combustion Engine ? )) has good compression. It is obviously a bit of a project but it has good bones to be somthing really cool.
Registered users: Bing [Bot], Google [Bot], Rppjr, Seansexton53
