It is currently Sun May 12, 2024 2:53 am
PostPosted: Fri Jul 31, 2020 5:33 pm
If you know where I can find 78.5 mm rings please let me know
thanks
PostPosted: Fri Jul 31, 2020 5:50 pm
if you have a good Honda dealer that is willing, some have a shared data base that they can check inventory of other dealers in the same system.
good luck
PostPosted: Fri Jul 31, 2020 6:35 pm
thanks
Just for fun I called Honda dealer near me.
The number I had her run was: 13013-VM0-305 Piston ring set
She said that it shows back ordered but the important part is that it did NOT show discontinued. She said it must still be in the system. If it's in the system then it's located somewhere whether it's here in Canada, USA or inventory somewhere she said. She also told me that it's $100 Canadian for the set. So obviously those rings are somewhere.
Get the Honda dealer near you to run the number.
The parts book I got does not indicate exactly what size those are but it does say: RING SET, PISTON (0.50)
If the original set was a 78mm then this set would be 78.5mm which is what you want.
PostPosted: Sat Aug 01, 2020 8:02 am
PM sent
Wyeeoddy
PostPosted: Sat Aug 08, 2020 9:47 am
https://www.ebay.com/itm/121832972525
PostPosted: Wed Aug 12, 2020 9:35 am
Has anyone received a reply from this post
Wyeeoddy
PostPosted: Wed Aug 12, 2020 7:39 pm
looking at his profile, he posted his question and has not been back since,
