It is currently Mon May 13, 2024 10:03 pm
 Post subject: FL350
PostPosted: Mon Jan 25, 2021 9:22 pm
Any of you yoyo's near napa county ??
Very reasonable price for an oddy but it's going to need a lot of work.
The description pretty much says it: "After cleaning the fuel tank and changing the old fuel lines it start right up. Ran just as fast and peppy as the last time I had used it."
:-) sure.
Here it is: https://sfbay.craigslist.org/nby/snw/d/ ... 17309.html
 Post subject: Re: FL350
PostPosted: Mon Jan 25, 2021 10:54 pm
"This posting has been flagged for removal."
When I clicked on it. What was it?
PostPosted: Mon Jan 25, 2021 11:35 pm
Holy cow that was a quick delete, only up for a couple of hrs after I clicked on it.
It was an FL350 for $600.
It obviously needed work but the description made me laugh.
He said: "Ran just as fast and peppy as the last time I had used it" LOL. Then he went on to tell you it has been sitting outside for 10 yrs and what he did to make it run and what some of the issues were. I loved the "cleaned gas tank, cleaned carb, changed fuel lines, changed sparkplug and it fired right up" LOL. "just as peppy as the last time I used it" LOL.
If you looked at it you knew it needed A LOT of work. Just be honest and don't ham up a pig and let the customer make the call if they want it. When a customer shows up then start it (IF it starts) and let them make the call. Oh yeah I forgot -- "the brakes work but the master cylinder leaks through the site glass so if you fix that and bleed the brakes everything will work" LMFAO. He also said that "the master cylinder has been freed up" :-) . Holy fk, anything else ?? But the price was real good but obviously to good to be true because this post is now flagged and gone LOL.
Oh well it's off line now.
PostPosted: Tue Jan 26, 2021 10:27 am
http://www.odysseyatvforsale.com/1985-f ... CRGo2DjsJo
This looks like the original post
