First I want to state that this all started because I found a prblem on my Pilot that needed to be fixed. When I put on the first disc brakes set up that I made I dicovered that the upper ball joints felt like they were really bad. This surprised me for 2 reasons. First it is usually the bottoms that go bad first and second the rest of my Pilot is in such good shape it just doesnt make sense. I really think the the guy that sold me this Pilot changed out bad parts that were on his other Pilot before he sold it to us.
Well when I took off the spindle I found that not only were the upper ball joints worn but one of them was close to braking apart all together. Then began the serch for a-arms. At the time that I was looking I could not find any that looked even halfway decent for over 4 months. This made me look for other ideas. I did not want to go with long travel for both space and money issues. I looked at doing an a-arm conversion using the arms from another vehicle. Then I had an idea. I thought that if I could hack off the ball joint from the stock a-arm that I might be able to put an after market balljoint through the center tube that was left in the middle. It took a lot of figuring out though before I actually hacked the arm.
I found high quality Italian made ball joints at alba racing for $20.00 ea and if you call and order direct they throw in free shipping. I driled it out with a 3/4" drill that just basically sleaned it up and evened it out throughout the entire center tube. Then I pressed in a 3/4 x 5/8 x 1 3/8 steel bushing into the center tube until it was flush on the back. Then I machined the front flush all the way across evenly. This is a pic of the ball joint in the a-arm after it was done and powder coated (I also added the eurothane bushing kit at the same time).
Now this would work for the stock spinde at the correct camber if I set it up that way but I had a lot of room to adjust and that led me to the second idea. A while back I found a disc brake conversion for the pilot that used the spindle hub set up from the TRX 450r. The only problem with it was the camber was not correct. A buddy of mine had the front end parts from an '05 and an '09 and sent them to me to try. I tried the '09 first (on the theory that newer is often better) and is needed so much adjustment for the camber that it would not work. Then I tried the '05 and it did work. I can hold from 0 to -3 degrees camber. I had read a lot about the difference between the '04-'05 and the later models of TRX spindles before I was done. It was a very interesting read. I looked on ebay and could see that people wanted a lot more money for the '04-'05 parts because they are in high demand by people that want to change out the font ends on their newer TRX for the old. Here are some sics of the mounted spindle with out them being diled in yet. They are just put on with some washers for spacers and the jam nut is not set yet.
