It is currently Mon May 13, 2024 5:01 am
 Post subject: 350 fuel gage mod
PostPosted: Wed Oct 24, 2012 1:51 pm
Here is a link to the fuel gage mod I did to the tank. Its a simple mag/reed switch that completes the circuit and turns on a light when the fuel level reaches about a 1/4 tank level.
viewtopic.php?f=2&t=2145&hilit=420
 Post subject: Re: 350 fuel gage mod
PostPosted: Thu Oct 25, 2012 3:24 pm
Sweet
PostPosted: Thu Oct 25, 2012 4:41 pm
Thanks Nukem! I'm going to add one of those to my buggy. How about showing off your brake light mod. I'd like to do that to mine as well. I wish these machines came with them. I'm worried someone might get into the back of me and tweak my frame.(the main reason I want to find a rear bumper.)
PostPosted: Thu Oct 25, 2012 5:07 pm
I know im no Nukem, but ive seen this used before http://www.motosport.com/motorcycle/WOO ... BANJO-BOLT
PostPosted: Thu Oct 25, 2012 5:18 pm
nitrosport_5 wrote:
I know im no Nukem, but ive seen this used before http://www.motosport.com/motorcycle/WOO ... BANJO-BOLT" .".." ."..
Thank you Sir! That looks easy enough. What about a 2stage bulb for my snorkel box? Im not positive but i think i need a different bulb? Doh! That means I gotta bleed these damn brakes again.(sad face)
PostPosted: Thu Oct 25, 2012 5:56 pm
If you still want to have a running light then u would need another light
PostPosted: Thu Oct 25, 2012 6:10 pm
Fatcat wrote:
nitrosport_5 wrote:
I know im no Nukem, but ive seen this used before http://www.motosport.com/motorcycle/WOO ... BANJO-BOLT" .".." .".." .".." ."..
Yeah you would need to modify the brake light box with a socket for an 1157 bulb. im sure you could use somthing like this to do so http://www.summitracing.com/parts/pco-5 ... dia/images
and in theory, bleeding the brakes should not be as bad since you arent loosing the prime through the master cylinder.
PostPosted: Sat Dec 22, 2012 12:08 am
got my switch put in
this is the one i got
http://www.amazon.com/gp/product/B00909 ... 03_s00_i00
