For you gun nuts I work on my saiga 12 and made a top gas tube rail for a scope
first one off the mill didn't turn out to bad need to remove that last slot where the screw is to make it look better
My son Jarred has been fitting the stock to the gun this week on and off
this has been a good quick project
speedchaser
Attachments: |
File comment: the stock is made by see pic I do not know if I would buy another one . there was a lot of fitting it was not a perfect fit out of the box. Plus they wanted you to cut the back of the stock mounts off but I made a 1" spacer for the but plate
