PilotOdyssey.com
http://pilotodyssey.com/PO/
Ben Pearson tube bender project from Fire sale
http://pilotodyssey.com/PO/viewtopic.php?f=46&t=4035
Page 1 of 1
Author:  speedchaser [ Wed Mar 05, 2008 9:21 pm ]
Post subject:  Ben Pearson tube bender project from Fire sale
Hello
Well found a Exhaust Pipe / Tubing Bender
That had my name on it. At $600
It was in a fire and got smoked
Me and the wife picked it up late last Friday
Man did it ever smell.
Me and my son at the age of 10 tore in all down and
Started to sandblast all the part that fit in the cabinet
Well the kid lasted a whole 20 min on the sandblaster
That he wanted to use so bad. So I finished up today 4 days later
And here are some picks
Thanks For Looking
Speedchaser
File comment: The MC-59 from Ben Pearson is truly the ultimate in pipe bender technology. Incorporating state-of-the-art technology, the MC-59 pipe bender leads the industry in operator convenience features --- 180 degree bend on 5" radius, 3" bending capabil
File comment: main beam
File comment: pivot arms
File comment: bottom tray and tank
File comment: cylinders and pump
Author:  speedchaser [ Wed Mar 05, 2008 9:31 pm ]
next
File comment: side shelfs
File comment: the smoked motor (( Internal Combustion Engine ? ))
File comment: some of the tooling
File comment: sandblasting cab
File comment: the pile of sand blasted parts
wow lot of work there
Author:  hoser [ Wed Mar 05, 2008 9:32 pm ]
Looks like a real project, do you think it will work again soon ?
Author:  speedchaser [ Wed Mar 05, 2008 9:40 pm ]
next
File comment: Here you go csi the main valve and relief valve
File comment: bottom bent a half of a inch
File comment: last one for the day trying to get the *anm thing flat
Author:  speedchaser [ Mon Mar 10, 2008 12:59 pm ]
next
short mov of tank in lathe
http://www.youtube.com/watch?v=4dXXnp0JJsc
thanks for looking
Speedchaser
File comment: welded some extra angle on bottom
File comment: primed with zinc
File comment: weld tubing on tank so I can put in lathe to clean all burnt rust out
File comment: close up
File comment: in lathe with a hand full 5/8" nuts and diesel fuel
Short mov. http://www.youtube.com/watch?v=4dXXnp0JJsc
File comment: some assembly and little paint
Author:  speedchaser [ Sun Mar 16, 2008 8:57 pm ]
Well got more done this weekend more paint too
thanks for looking
speedchaser
File comment: more assembly new used motor (( Internal Combustion Engine ? )) updated to 3ph 5hp
File comment: sand blasted cylinders and some painted bend tools
File comment: kid out playing in mud with snowsuit
on
File comment: color coded tooling pre size
File comment: side veiw last pic for today
thanks for looking
Author:  marioparra78 [ Tue Mar 18, 2008 1:36 am ]
What are your plans with this machine do you have your own shop? Or is just for your own use. I just paid 20 bucks to have a spark arrestor adapted to my dg exhaust and they used a machine that looked just like that one.
Author:  Drakman [ Tue Mar 18, 2008 10:50 am ]
Yeah, I've been curious also. That looks like serious machinery, can't wait to see what you make with it.
Author:  speedchaser [ Tue Mar 25, 2008 10:14 pm ]
Hello I do have my own shop witch I do prototype furniture parts.
I had been looking for this type of bender to do other then guts round tube.
It great that it has the dies that go from 1-1/2 to 3” round
I think that my neighbor has his mind going all over the place with ideas.
And as my son gets older I will be getting back in mud bogging. And doing my own frames, bumpers, side bars and roll cages ext
Know back to work found one cylinder end cap with broken ear witch is cast iron
And main top cylinder the rod looked like they took a hammer to it. So I made a new
one. Here are sum more pic’s
Thanks for looking
speedchaser
File comment: time to pre heat the cast iron to aprox 900 F
File comment: getting hot. Tip for the day your spit will bounce off the hot steel at 600F see old cylinder rod in back ground some one got happy with a hammer
File comment: weld up
File comment: other side
File comment: went and added a washer to the top
to help support the load
File comment: all done welding
Author:  speedchaser [ Tue Mar 25, 2008 10:23 pm ]
next
The rest of the cylinders and pump where all rebuild able with new seals
The two manual valves needed seals and handles the handles melted off
File comment: bottom side of cap cleaned up in lathe
File comment: new machined rod 2" dia x 23" long
File comment: threaded end 1-1/4-12 thread
Author:  hoser [ Wed Mar 26, 2008 5:22 pm ]
Nice work!
Almost done?
Author:  speedchaser [ Sat Apr 05, 2008 9:14 pm ]
all the paint done today fist nice day to paint out side
Author:  speedchaser [ Thu Apr 17, 2008 6:04 pm ]
Getting close on finishing this project up
Assembly time And time to make new hoses
File comment: SOME Assembly
File comment: more
File comment: mount motor (( Internal Combustion Engine ? ))
File comment: hose time pluming
File comment: gage pressure relief
File comment: more
Author:  speedchaser [ Thu Apr 17, 2008 6:14 pm ]
hose crimper and last pic for the pluming
next Electric panel wiring
thanks for looking SpeedChaser
File comment: crimper hose
File comment: last pic for the day thanks for looking SpeedChaser
Author:  hoser [ Thu Apr 17, 2008 7:05 pm ]
Looking good how long before you bend pipe?
Author:  speedchaser [ Sun Oct 12, 2008 8:03 pm ]
well I finished up the bender last week
all in all things went very well bender is like new
Today Made some new tooling so I can bend 1-1/4" tube
see pic's
thank for looking
SpeedChaser
File comment: cut out side shape and pocket
File comment: that block is from the furnace project
poured from melted 6061 scrap
File comment: cut radius in side
File comment: all fitted in bender with slider blocks
Author:  hoser [ Mon Nov 17, 2008 4:26 pm ]
Any updates here?
https://www.phpbb.com/
