PilotOdyssey.com
http://pilotodyssey.com/PO/
Fl350 front suspension rebuild
http://pilotodyssey.com/PO/viewtopic.php?f=46&t=4712
Page 1 of 1
Author:  speedchaser [ Sun Oct 12, 2008 8:47 pm ]
Post subject:  Fl350 front suspension rebuild
Hello All I Thought I would do a easy front J arms replacement
this weekend. Well that didn't happen
I opened a can of worms It started out both tie rod are bent the replacement J arm bushings weren't to
my spec. and the cross bar is all bent up. So this is where my weekend started. Well time to do some ((( Hacking )))
Thank for Looking
SpeedChaser
File comment: J arm bushing not to Spec
time to make some new
File comment: made some up out of 1" black pipe
one piece and cut the head of the stock bushing so it will still seal on ends
File comment: grabbed some Dana 44 pinion shims
so i can tighten up the side play
File comment: Close up end up Adding .010 on each j-arm this made a big difference on the slop
File comment: The beat up cross bar
File comment: Next view
Author:  speedchaser [ Sun Oct 12, 2008 8:57 pm ]
Next
File comment: Hi low work good for a lift
File comment: Time to bend up some tube
Went with 1-1/4" instead of the 1-1/8"
File comment: Cut to length and coped
File comment: tacked into place
File comment: fitted center tube
File comment: All welded in
Author:  speedchaser [ Sun Oct 12, 2008 9:05 pm ]
Well that it for now it should ride and steer like new
Thanks For looking
SpeedChaser
File comment: tie rods installed
File comment: next
File comment: next
File comment: Time for spray primer
File comment: And slap some paint on
not for show
Author:  Twilight [ Sun Oct 12, 2008 9:30 pm ]
Its the newest looking part on the whole machine, haha Good job! looks very nice.
Thanks for the head too =) Just wish the mailman didnt cram it into my mailbox so much that it broke the mailbox, haha
Author:  hoser [ Mon Oct 13, 2008 6:39 am ]
Nice work.
Looks like a good place for a skid plate?
Author:  mudbogger [ Mon Oct 13, 2008 5:35 pm ]
Any thoughts on the J-arms replacement tie rod ends Speed?That would be sweet indeed!!
Author:  adnoh [ Mon Oct 13, 2008 8:37 pm ]
Nice Hacking or sholud we call it skilled hacking, back yard is alread taken. That fix it kit will help a lot of fl350 owners. Man, I bet you have fun working on bikes. Does you head hurt any from all those ideas. Nice work.
Author:  Sunblock [ Mon Oct 13, 2008 9:35 pm ]
Nice work, what type of welder did you use to repair the frame? I need to pick one up that can handle an ody frame.
Author:  mudbogger [ Wed Oct 15, 2008 9:35 pm ]
Speed, do you have the tie rods mounted correctly-doesnt 1 mount from underneath and 1 side from the top?
Author:  speedchaser [ Mon Oct 20, 2008 6:59 pm ]
Speed, do you have the tie rods mounted correctly-doesn't 1 mount from underneath and 1 side from the top?
Well I did have it wrong but the outer the manual doesn't show it on the left side well
any way the steering wheel bushings where whore out
so I had to make some new
Made them out of bronze and added grease zerts
thanks for looking
Speed
File comment: Old and new bushings and shaft
File comment: steering wheel end with zert
File comment: with shaft in
File comment: other end pivot with zert
Author:  stix [ Mon Oct 20, 2008 11:15 pm ]
Good place for a zert, man now I have another project times 2
Author:  mudbogger [ Sun Mar 06, 2011 3:56 pm ]
Post subject:  Re: Fl350 front suspension rebuild
Speed, do you have any of these bushing left over by chance? I could use 4 of them.
Author:  speedchaser [ Sun Mar 06, 2011 6:07 pm ]
4 bushings
or 4 sets ?
Speed
Author:  mudbogger [ Sun Mar 06, 2011 7:56 pm ]
4 bushings
or 4 sets ?
Speed
4 of the steering wheel bushings. They mount in the steering shaft column.I have 2 sets of the j-arm bushing kits already. :-)
Author:  speedchaser [ Sun Mar 06, 2011 8:19 pm ]
4 bushings
or 4 sets ?
Speed
No that was a one time thing at the time you think there is a need for them in a kit form ?
Honda make stock ones still ?
I will look in to it Monday
speedchaser
Wow Thanks Hoser for the sub forum just noticed that :-)
Author:  mudbogger [ Sun Mar 06, 2011 8:43 pm ]
I think they have been discontinued for sometime Speedchaser---but I might be wrong.
Author:  crackerwarrior [ Sun Jan 31, 2016 12:17 am ]
Nice id like the steering stem bushings too lol
https://www.phpbb.com/
