DIY Fender Repair plastic Welding http://pilotodyssey.com/PO/viewtopic.php?f=46&t=5199 |
Page 1 of 1 |
Author: | speedchaser [ Sat Feb 21, 2009 4:57 pm ] | |||||||
Post subject: | DIY Fender Repair plastic Welding | |||||||
Hello Did some fender repair Pick up A cheap plastic welders from harbor Fright Item # 41592 and some screen for cement block or brick work Tools needed putty knife sheet steel shears and plastic welder The weld stick that came with the welder I didn't like. so I cut up some plastic from a old fl350 tub I had laying around The main thing when doing this is to block up the back side of fender with wood or steel Thanks For Looking SpeedChaser
Author: | speedchaser [ Sat Feb 21, 2009 4:58 pm ] | |||||||
Post subject: | ||||||||
Next
Author: | speedchaser [ Sat Feb 21, 2009 5:11 pm ] | |||||||
Next
Author: | speedchaser [ Sat Feb 21, 2009 5:22 pm ] | ||||||
Closes Ups Thanks For Looking SpeedChaser P.S. I would Like to thank Hare For the Screen Idea as he gave the Idea out in chat Thanks
Author: | hoser [ Sat Feb 21, 2009 7:40 pm ] |
Post subject: | |
Wonder if you heated up the mesh with a torch until it was red hot then let it burn into the plastic until it was flush then finished it off as you did? |
Author: | speedchaser [ Sat Feb 21, 2009 8:06 pm ] |
Post subject: | |
hoser wrote: Wonder if you heated up the mesh with a torch until it was red hot then let it burn into the plastic until it was flush then finished it off as you did?
Yes you can I use to use a torch screw driver and putty knife to fix the plastic fenders and gas tanks one time we where out camping and need to fix a gas tank I use part of the guys rear fender a screw driver and camp fire . this was way bake in the late 80's and it still doesn't leak to this day. Thanks SpeedChaser |
Author: | mozzy [ Sun Feb 22, 2009 10:11 am ] |
Post subject: | |
Damn you're good with tools. |
Author: | vectorboy_99 [ Mon Feb 23, 2009 9:36 am ] |
Post subject: | |
This is timely. I just bought a project for the kids yesterday, and need to fix the fenders. What a coincidence. thanks, Jim |
