PilotOdyssey.com
http://pilotodyssey.com/PO/
speedchaser fl350 bottom ends and starter mods
http://pilotodyssey.com/PO/viewtopic.php?f=46&t=5521
Page 1 of 2
Author:  speedchaser [ Mon May 25, 2009 6:30 pm ]
Post subject:  speedchaser fl350 bottom ends and starter mods
Hello Rebuilding four bottom ends that I had collected over the years.
File comment: getting them cleaned up hot pressure washer steam 1500psi 350deg and mag aluminum cleaner
File comment: the steam cleaner
File comment: transmission I threw in to clean
File comment: all cleaned up
Author:  speedchaser [ Mon May 25, 2009 6:31 pm ]
FL350 balancer case vent mod By Speedchaser
File comment: started out today to weld up all cracks in cases and weld block on for vent tube
File comment: drilled and partially tapped 1/8 -27 npt
File comment: lining them up to see how it looks
File comment: beveled one end to fit radius
File comment: all clamped up and ready to weld them up
Author:  speedchaser [ Mon May 25, 2009 6:38 pm ]
File comment: all of the cases that had a piston go bad in it. seem to have cracked or pushed out side wall from a chunk of piston run threw or around the crank.
File comment: all vent block all welded on man they look ugly
File comment: closeup
File comment: thew them in mill and deck them down and fished drilling threw the case and finished tap by hand
File comment: all finished on that part different styles of hose barbs will see what is needed when I get one in a frame
Author:  speedchaser [ Mon May 25, 2009 6:50 pm ]
that it for today thanks for looking
need to do finish work and lap the case side flat
SpeedChaser ::-:
File comment: time to weld up vent hole for starter mod
File comment: all welded up
File comment: this when I found a different s in the case webbing they must have change them mid year the older and more webbing
File comment: new style case
shouter webbing
Author:  Sunblock [ Mon May 25, 2009 10:20 pm ]
awesome speed, I hope to have your fabbing skills one day. why did you choose to use the extra block of aluminum to thread the breather flange instead of just taping the case directly? More room for error or such ? What will you be doing with all these bottom ends once they are completed?
Author:  shoubadaba [ Tue May 26, 2009 10:56 am ]
Looks good speed.
Author:  speedchaser [ Tue May 26, 2009 8:54 pm ]
There was not enough material in that area so I add some more thickness
because I didn't want to chance that thin of area to brake off if the hose barb got hit by chance
thanks SpeedChaser
Author:  speedchaser [ Tue May 26, 2009 9:15 pm ]
Hello today got some more stuff done
started out doing some hand lapping on the granite surface plate
thanks For looking
speedchaser
File comment: I like to use spray disc adhesive
on the 3m paper to hold it down
File comment: I like to start out with 220 grit then move to 400 grit
File comment: I use layout die on the surface
before I start lapping
File comment: this what happens when a chunk of piston get run threw the crank it pushes the walls of the case out
File comment: after all the surfaces are done cleanup
and install dowel pins and bolt them back together
File comment: Tech Tip for the day
to remove cylinder main studs use the front or rear lug nuts off your ride
lot bigger nut .
Author:  speedchaser [ Tue May 26, 2009 9:17 pm ]
next
File comment: all ready to lapp the last surface
File comment: knock off all sharp edges
File comment: amazing how far off they are from the factory
Author:  speedchaser [ Tue May 26, 2009 9:30 pm ]
next
File comment: did some measuring center of the bearing to the top of the case deck
File comment: here are my chicken scratches
all the deck heights are pretty close
Author:  speedchaser [ Tue May 26, 2009 9:31 pm ]
hear are my other notes
from measuring today
finding the distances between the main bearings ,crank to the case half when assembled
after all the numbers floating around in my head
I started to re tap all the threaded holes in the case half's
tomorrow will start on doing some Hoser porting on the oil hole going to the bearings
then off to the dish washer for final clean as long as the Wife don't see me doing it haha :-)
that it for now
SpeedChaser
File comment: this is the gap on the big end of the rod bearing
Author:  vectorboy_99 [ Fri May 29, 2009 9:26 pm ]
A practical use for a kitchen appliance nice.
Jim
Author:  speedchaser [ Thu Jun 04, 2009 9:25 pm ]
Jim
It was not a good idea to run in dish washer it will make the casting corrode with white hair
had to re power wash with steam cleaner with mag aluminum spray
got more stuff done on the cases installing bearing the red neck way with the ready heater.
Thanks for looking
SpeedChaser
File comment: preheating
File comment: the spray oil that I use to coat the case before heating them up it will leave a nice coating on the outer case that looks like stock finish
File comment: note the shinny finish it stay that way when cooled off and wipe down
File comment: ntn bearings
File comment: the bearing drop rate in the case half's
after it is heated up
next
Installing seals
Next step is getting cranks ready to install and putting case half together
Thanks For Looking
SpeedChaser
File comment: well last one today
Author:  stix [ Thu Jun 04, 2009 11:02 pm ]
Good stuff here! Where did you get you bearings from and seals. Im fixin to need all that stuff, Should I order from Service Honda or get them aftermarket? I have a couple bearing suppliers close to my shop. After talking to you and Hoser about my basket case halves I guess I will hang on to them and fix. Thanks Speed
Author:  speedchaser [ Fri Jun 05, 2009 7:23 am ]
Hello I went to service Honda for seals and new dowels
now the bearing I went to Motion Industries personal preference
service Honda is where you should go for bearings.
But if you decide to go some where else stick with the NTN bearings and numbers for the fl350 I have Above
that is the same numbers that Honda uses. The main thing is to stick with the c3 rating.
Your Case if you want to you can send it to me to look at if you would like.
Or start a new thread and I will help you with it there too as will others.
Thanks Speedchaser
Author:  stix [ Mon Jun 15, 2009 8:07 pm ]
Hey Speed. I might know someone here in town that can fix the hole in the case and if not I might take you up on your offer. I went by the bearing supplier today. This particular supplier had Koyo and not NTN. Im not sure if they are C3 rating, do you know. There is another supplier I can go to, I think his are NTN. Kinda upset me cause the guy said he had NTN then when I show up they are Koyo. He said NTN quit giving him "deals" on thier bearings so he started carrying the Koyo, he says they are made in Japan which means nothing to me unless they will hold up as well as the C3 rated or Honda's, BTW Service Honda can only get one of the crankshaft bearing and only has one of the balancer bearings....
Author:  hoser [ Mon Jun 15, 2009 8:28 pm ]
This is exactly why I buy my bearings from Honda, seems now days bearing suppliers are a bunch of whores looking to buy the cheapest shit they can buy and sell to you at the same price the better bearing sold for, 20 years ago bearing suppliers would only sell the highest quality bearings and if they had complaints about short lived bearings would quit carrying that line of bearing, you also could take a old failed bearing with you to the parts house and some old guy would take it into the back room, clean it then examine it to determine why it failed then suggest a cure for the failure, 99 times out of 100 he was right, better seals, high temp grease, different bearing that had more balls in it for the same size races etc. now you take a bad bearing in the punk ass clueless mutt behind the counter says he has no clue he just sells the bearings.
My reasoning for buying from Honda is suppliers will not send them junk low quality bearings for fear of losing their account with them, I could be all wrong and am paying way too much for bearings. :shock:
Author:  speedchaser [ Mon Jun 15, 2009 8:55 pm ]
the c3 rating will be at the end of the part#
and make sure that they are c3 rated
Honda runs NTN
where are your old bearings ?
If you still have them do they slide in the case half's ?
because they suppose to press in not slide
we want to check this first be for you go out and send money on bearing and find out the case half's are junk !
I have old bearing if you need them for checking the out side diameter only or find some body that can mesure the case half's bearing o.d. for you I have posted my findings in this post
thanks Speed
Author:  stix [ Mon Jun 15, 2009 9:04 pm ]
I have the old bearings and when I install them they do slide in tight but I can slide them in with my hands. Is this too loose, can I use a cylinder locking compound or is that out of the question. Ill have to check to see if the Koyo are c3. I will probably just go with the NTN if the other supplier isnt a liar also....unless my case halves are junk ?? :shock:
Author:  speedchaser [ Mon Jun 15, 2009 9:35 pm ]
as long as they don't feel lose when all the way in
you could use retaing compound but if you had to split the case again it could make problems for you later down the road. Where you would have to preheat the case to get it apart !
but it's your Engine. and I'm no expert on two stork Engines.
I just read and learn like the rest of us.
Thanks SpeedChaser
Author:  stix [ Mon Jun 15, 2009 9:42 pm ]
but it's your motor (( Internal Combustion Engine ? )). and I'm no expert on two stork motors.
Thanks SpeedChaser
When they are installed they don't feel loose at all, but I don't have to use a press to get them in the case. I guess if my cases are on thier last leg, I might as well get another bottom end out of them and use the retaining compound. Im no expert on two storks either, just learning as i go!
Author:  speedchaser [ Sun Mar 07, 2010 4:27 pm ]
all finished up ! Time to bag em and tag em
Tell Next Time
Thanks Speed
MVC-278X.JPG [95.7 KiB]
Downloaded 215 times
Author:  mudbogger [ Sun Mar 07, 2010 4:32 pm ]
Selling them by chance Speedchaser? I could use a fresh bottom end for sure!!!
Author:  speedchaser [ Sun Mar 07, 2010 4:35 pm ]
Hello Mud not at this time I have 2 to finish up this year and two Engine's go in running rides that need freshening up
thanks Speed
https://www.phpbb.com/
