FL350 - Polishing of the Turd. http://pilotodyssey.com/PO/viewtopic.php?f=48&t=6091 |
Page 1 of 1 |
Author: | Tpreed [ Tue Oct 13, 2009 5:59 pm ] | |||||||
Post subject: | FL350 - Polishing of the Turd. | |||||||
viewtopic.php?f=5&t=5938 - original poofkaboom thread Well.. Ive decided to polish the turd. (maybe it wont looks so turdlike when im done) here are some pics of tons of random stuff.. even some pics of rebuild parts, we all love pics of parts right?
Author: | Tpreed [ Tue Oct 13, 2009 6:39 pm ] | |||||
Post subject: | ||||||
more
Author: | Turbotexas [ Tue Oct 13, 2009 7:02 pm ] |
Post subject: | |
did you spray paint the bolts on the roof and cage??? |
Author: | Tpreed [ Tue Oct 13, 2009 7:58 pm ] |
Post subject: | |
Turbotexas wrote: did you spray paint the bolts on the roof and cage???
oh yea.. im just gonna spray everything lol. maybe ill get the motivation to take it apart and do it right here soon. i probably shouldn't have done that im guessing. does it look really bad? |
Author: | Turbotexas [ Tue Oct 13, 2009 9:10 pm ] |
Post subject: | |
Tpreed wrote: Turbotexas wrote: did you spray paint the bolts on the roof and cage??? oh yea.. im just gonna spray everything lol. maybe ill get the motivation to take it apart and do it right here soon. i probably shouldn't have done that im guessing. does it look really bad? yea...real bad |
Author: | Tpreed [ Tue Oct 13, 2009 9:31 pm ] |
Post subject: | |
Turbotexas wrote: Tpreed wrote: Turbotexas wrote: did you spray paint the bolts on the roof and cage??? oh yea.. im just gonna spray everything lol. maybe ill get the motivation to take it apart and do it right here soon. i probably shouldn't have done that im guessing. does it look really bad? yea...real bad lol damnit. yea i actually gave it a good look and i have to agree. i should pull them out and hit them with some brake cleen lol |
Author: | Tpreed [ Wed Oct 14, 2009 4:21 pm ] | ||||
ok so today i wire brushed the new cylinder up a bit.. soaked it in a hot water/degrease bath.. i have to say it looks better here are pics of the before after
Author: | Tpreed [ Thu Oct 15, 2009 11:33 pm ] | ||||||
Post subject: | |||||||
got the cases split today they were nasty.. heres before and after cleanup. i used a fine wire wheel and a ph stable emulsifier (dawn dish soap). i changed the direction of the spin to avoid gasket surfaces, so the wheel wouldn't wrap around the edge. next victim of my wire wheel will be the tranny. lets just say i wouldn't exactly eat off of it. im not quite sure why i have two threads at the same time... the difference in the two being... this one is for random cosmetic and has to do with the whole machine.. the other is for the motor (( Internal Combustion Engine ? )) alone. ok now that i have that figured out in my mind... on to the before and after
Author: | Sunblock [ Fri Oct 16, 2009 4:52 pm ] |
Post subject: | |
looking good ... |
Author: | Turbotexas [ Fri Oct 16, 2009 9:15 pm ] |
Post subject: | |
for those of us on dial up technology... http://www.pilotodyssey.com/PO/viewtopic.php?t=3227 |
Author: | Tpreed [ Fri Oct 16, 2009 10:49 pm ] |
Post subject: | |
Turbotexas wrote:
lol sorry turbo i forget your on the cell card |
Author: | Tpreed [ Tue Oct 20, 2009 1:41 am ] |
Post subject: | |
no pics this post.. pulled and cleaned the tranny up.. painted random stuff.. sometime this week i will remove the wiring harness in the rear and clean/paint the frame |
Author: | hotrodd [ Wed Oct 21, 2009 9:45 pm ] |
Post subject: | |
Nice progress, the cases look nice. you can use this http://www.plastikote.com/plastikote/au ... =Rebuilder after the cases are clean. I use it on all my honda engines(mostly cars) when the engines are out it gives the look of stock cast aluminum. The dirt doesnt stick to it as easy as the bare metal too. My fl250 motor (( Internal Combustion Engine ? )) is going to get a coat of this when it goes back together. if you leave it looking polished like that it will oxidize and look nasty in no time. this paint is the only way I have found to keep things looking stock and not have to clean it so often. what speed of dial up is it? my phone loaded the page with pics in 20 seconds |
Author: | Tpreed [ Wed Oct 21, 2009 9:52 pm ] |
Post subject: | |
hotrodd wrote: Nice progress, the cases look nice. you can use this http://www.plastikote.com/plastikote/au ... =Rebuilder
after the cases are clean. I use it on all my honda engines(mostly cars) when the engines are out it gives the look of stock cast aluminum. The dirt doesnt stick to it as easy as the bare metal too. My fl250 motor (( Internal Combustion Engine ? )) is going to get a coat of this when it goes back together. if you leave it looking polished like that it will oxidize and look nasty in no time. this paint is the only way I have found to keep things looking stock and not have to clean it so often. what speed of dial up is it? my phone loaded the page with pics in 20 seconds ahh yes.. this is what speedchaser was telling me about thanks for the link im going to order this up! |
Author: | speedchaser [ Thu Oct 22, 2009 7:45 pm ] |
Post subject: | |
Tpreed wrote: hotrodd wrote: Nice progress, the cases look nice. you can use this http://www.plastikote.com/plastikote/au ... =Rebuilder after the cases are clean. I use it on all my honda engines(mostly cars) when the engines are out it gives the look of stock cast aluminum. The dirt doesnt stick to it as easy as the bare metal too. My fl250 Engine is going to get a coat of this when it goes back together. if you leave it looking polished like that it will oxidize and look nasty in no time. this paint is the only way I have found to keep things looking stock and not have to clean it so often. what speed of dial up is it? my phone loaded the page with pics in 20 seconds ahh yes.. this is what speedchaser was telling me about thanks for the link im going to order this up! Tech Tip Of The Day Hello if you really want the case half clean call up your local transmission re-builder and ask if they will run it threw there cleaning tank it will come out looking new again Speed Chaser |
Author: | hotrodd [ Thu Oct 22, 2009 8:55 pm ] |
Post subject: | |
If you have a tractor supply near you that's where I got the paint its like $6 a can |
Author: | Tpreed [ Tue Mar 09, 2010 11:40 pm ] | |||
:) thank you hoser!
Author: | hoser [ Mon Mar 15, 2010 3:28 pm ] | ||||||||
Post subject: | |||||||||
Here are the pics on the inside of your starter...
Author: | Fatcat [ Sun Dec 09, 2012 9:02 am ] |
Post subject: | Re: FL350 - Polishing of the Turd. |
Hi Tim, had any free time to work on your ride? How about some updated pics with the hood and side panels on? I'd like to see how it turned out. Done any riding? |
