Kuma,
I have been looking into the solenoid valve but for now I have been conscious about turning it off when it’s not running and the issue is gone for now. I have also been wondering if this was due to the carburetor float level not being set properly when I first started it, Causing the bowls to overfill. Do you have a suggestion on a different style filter? I don’t do much sand riding, but I would like to keep the intake system as clean as possible.
I got some fenders on it and it’s looking like a pilot again. Definitely need some new rear tires. The original ones that are on it have good tread and are not dry rotted but the rubber is quite hard and I’m spinning the wheels quite a bit on acceleration. Also, my belly pan skid plate won’t work with the nerf bars so I’ll have to modify it at some point. I’ll be taking it up to New Hampshire this weekend and will put it to the test.
